Question about Tools & Hardware - Others
How do I change the brushes on my Craftsman 2.0A Multi-Tool
2 Suggested Answers
  • 7 Answers
SOURCE: How to replace brushes?
On either side of the switch is a black disk with a notch small enough for a small screwdriver. Unscrew it and take it off to expose the spring. Gently pull the spring out and the brush should be attached. If you encounter resistance, then you may disconnect the spring from the brush. If this happens then push the spring back in and hope you catch the brush; if this does not work, then get creative or take the whole thing apart to get to it. After that, just put the new brushes in and recap.
Posted on Aug 03, 2008
How do i service or change brushes in my 1955 craftsman oiless sprayer
Contact Craftsman unless it is now too old and if so check with a small appliance/tool repair shop in your area
Oct 15, 2014 | Air Tools & Compressors
Location of brushes on dremel multi max kit
There should be a second brush. Look along the motor - you're looking for a spot where the armature (the part that rotates) is surrounded by a ring of little straight copper-colored bars. That's the "commutator" section. The brushes run against the copper bars.
Look on the outside of the plastic shell - there may be two large plastic screws, one on the outside of each shell half, right about where the commutator would be on the inside. Those are your brush holder screws; you should be able to change the brushes from OUTSIDE the tool without opening it. Some tools are built without external brush holders like that, but most have external brush holders.
If you find external brush holder screws, then track down the second brush and set it aside. It MAY be hanging from the brush holder in one of the shell halves. Unscrew both brush holders and remove them from the shell. Set them aside and reassemble the motor back into the shell. If the brushes are really short, like if they're nearly cube-shaped, then it's time to replace them. If not, try them again.
Insert one brush into each of the holes the brush holder screws came out of, and put the brush holder screws back in. Be careful not to cross-thread them. Try the tool.
If it still won't run, it's possible that an armature winding has given up the ghost and it's time to replace the tool...
Jul 11, 2014 | Dremel Multi Max Kit
How do I get to the brushes in my Craftsman 2.0A Multi-Tool?
Call Sears parts at 1-888-204-3725 describe your tool and ask for a users manual and a parts explosion map.
Oct 20, 2013 | Tools & Hardware - Others
Craftsman model 137.216100
Maybe the brushes are stuck.
Aug 29, 2013 | Home Security
How to change the brushes in the older Craftsman tool. Seems they are placed in the motor and the end closed by small tabs bent down?
if that is the case without having the model number it sounds like they are not replaceable and you would have to buy a motor assembly. Alot of tool mfrs did not make these brushes replaceable.
Jun 26, 2011 | Craftsman 14.4 volt Cordless Drill/Driver...
Have a MODEL 572.610530 CRAFTSMAN ROTARY TOOL. TURNED ON UNIT AND BEFORE I STARTED USING IT, THE TOOL SHUT DOWN. I EVEN CHANGED OUTLETS TO MAKE SURE IT WASN'T THE OUTLET...IS THERE A WAY TO RESET TO...
Hi and welcome to FixYa, I am Kelly. First off you did not mention the age of this tool which would have been quite helpful in my response.
I looked up your parts here:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Rotary-tool-Parts/Model-572610530/0247/0741520/10043672/00001?blt=06&prst=0&shdMod=572610530
You should inspect the brushes (item 11) for wear or broken springs. From what I can tell this particular model has been in the retail market place for at least 10 years. This would lead me to believe that the brushes are suspect. The brushes can be removed by unscrewing the opposing "screwdriver slotted" plastic caps on the outside of the tool and then carefully lift them out for inspection.
Use a flashlight and inspect the armature where the brushes come into contact. It should be shiny copper colored and not dark or black.
I also note that the switch has 5 speeds. Since it does not work on any speed... I doubt the switch has failed.
Detailed view:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f10043672-00001.png
Your manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0709185.pdf
If you have more questions after inspecting the brushes, feel free to respond anytime with those questions
Thanks for choosing FixYa,
Kelly
May 18, 2011 | Craftsman Tools & Hardware - Others
Need a set of Brushes for a Craftsman circular saw model 315.27802 I tried Sears Parts and they are no longer available. Bill wyuhasse@atmc.net
Try anyplace that handles electric motor repair or tool repair. Most brushes are standard and probably a set from a black and decker saw will fit
Feb 16, 2011 | Craftsman Saws
Apr 24, 2008 | Dremel Variable - Speed Multipro Rotary...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
