Samsung MM-E460D cd player won't activate - Audio Players & Recorders
How do I connect my Yamaha RX-V733 to a CD Player?
I don't see a RX-V733 on Yamaha's site. However, look for a stereo audio input on the receiver. Then use the appropriate audio cable or adapter for the CD player audio out.
Depending on the CD player, you should use either an RCA M/M to RCA M/M (red/white) audio cable or a 3.5 mm headphone to RCA stereo audio cable. (If you don't have a headphone to RCA stereo audio cable, you can use adapters on either side. Examples: 3.5 mm M to RCA F/F adapter to RCA audio cable as above or 3.5 mm M/M cable to 3.5 mm F to RCA M/M audio adapter, depending on which cable you want to use and where you connect the adapter.) After making this connection, turn on the CD player, select the appropriate input.
The connection for an external audio device (like a CD player) is shown on page 31 of the manual for the RX-V773. Even if this is a slightly different model, the image may help. The manual is available from Yamaha on the product page: http://au.yamaha.com/en/products/audio-visual/av-receivers-amps/rx-v773_g/?mode=model . Click on the Support tab. The direct link to the manual is http://download.yamaha.com/api/asset/file/?language=en&site=au.yamaha.com&asset_id=54075 .
I hope this helps.
Feb 21, 2017 | Yamaha Audio Players & Recorders
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Dr dre headphones won't work with my portable CD player
Try the Soul By Ludacris. They look nicer and they work http://bestheadphones-review.com/soul-by-ludacris-sl300wb-high-definition-noise-canceling-headphones-review/
Jan 20, 2013 | HP Beats By Dr. Dre Solo Headphones,...
Playing ipod on samsung MME460D
I've just been struck down with this too on my newly purchased MM-E460D. I think I've worked it out, its just a poor description and manual. iPod mode" means choose the music off the iPod via a connected TV whereas "Remote iPod" is choose the music off the iPod via the Samsung remote and also directly from the iPod interface. I've been there for days trying to get "iPod mode" to work via the iPod interface.
Oct 01, 2012 | Samsung HT-Z310T Theater System
Can I connect my YP-U3 MP3 player to a car stereo? If so, what kind of connection lead will I need?
well it has a regular 3.5 mm jack. you can get a universal fm radio transmitter that plugs right into it, tune your radio, and listen in. I on the other hand, have a car with a tape deck, and just used the tape adapter from an old cd player i had, that plugged right into the headphone 3.5 mm output.
Dec 31, 2009 | Samsung YP-U3 MP3 Player
The player only intermittently recognizes CDs inserted; it does not seem to make any difference whether they are commercial, recorded at home, etc. Sometimes it says "insert disk," sometimes "no disk." ...
A CD tray is usually powered by a rubber strap, the belt can slip through, causing the electronics to miss the input timing, including a microswitch or copper contact which is activated at the closed disc tray so that the laser is focussed to read the table of contents Due to the fact that the spindle motor is activated. And in some players (interchanges there is also a selects witch that can be contaminated. a suggestion to help in the link
How to Fix DVD or CD Player That Won Open
Jun 30, 2017 | Philips CDR950 CD Recorder
Won,t play region 2 dvds it comes from america
America is region 1, thats why it will not play. The best luck I have had with region free dvd players is the cheapest you can find will play almost anything but they dont last
Jul 15, 2009 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Yh-920
http://downloadcenter.samsung.com/content/MM/200212/um_yh920_html_eng_040820.html
Jun 25, 2008 | Samsung Napster YH-920 MP3 Player
Won.t play
on some cd players, when they are closed ,they also push a button or little springloaded switch to let it know its loaded. Now eventually these doors wear down and dont quite push the activation switch all the way
yours is inside the box and can sometimes be temporirily jammed down with blue tack or tape
Ive had the same problem and in the end its time to buy another system my friend
Clapster
Jan 29, 2008 | Philco (R) 841.205 CD Shelf System
 Grubhead
Grubhead
