Question about Sharper Image The 8149SI Stainless Steel Pressure Cooker
NEED A REGULATOR KNOB - Sharper Image The 8149SI Stainless Steel Pressure Cooker
  • 24 Answers
Probably not going to find the regulator knob for this unless u still own the user guide and manual which may list replacement parts. I only found this model to be digital with no knobs that I can see. if u just need a knob cause u lost or broke just the knob and not the shaft u may find a guitar knob for volume control and tone control may be something to look into as you can find thousands of different styles of knobs at any music shop like guitar center or a local shop. you may be able to adapt something like that and have a custom 80 dollar pressure cooker.
Posted on Oct 21, 2013
  • shizznat Oct 21, 2013
    try to contact customer support for sharper image they may point u in the exact replacement part if they are available
Need a replacement regulator knob for my pressure cooker # 99700
Fixya does not sell replacement regulator knobs.
Oct 30, 2017 | Home
I got a new 40" propane smoker. I keep having problem with a flare up behind the regulator knob. The first time I used it it ended up melting the knob and the igniter. I got a new hose thinking there was...
If you have flames coming out of the regulator knob, you need a new one under warranty. There should not be gas escaping from anywhere.
Jul 31, 2017 | Grilling
Brand new compressor...air builds in tank but turning the regulator result in no change in the regulated pressure. Tried turning the regulator to make sure it moves freely, and it seems to, but still no...
The regulator has a very strong spring inside causing knob to get harder to turn as you increase the pressure (increase clockwise). If the knob is easy to turn most likely stripped inside. If knob gets tight as you turn then plunger at rear of regulator is stuck. On the back side of the manafold directly opposite the adjustment knob is a small nut housing a plunger. Let out all the air from the tank and remove the nut. Seperate the nut and plunger, lube and re-install. If the regulator knob is stripped you will need to replace the manafold or as a temp fix remove the safety valve (let out air from tank first) and install a tee fitting. On one port of the tee reinstall the safety valve and on second port install quick fitting for full tank pressure (or install aftermarket pressure regulator ).
Oct 28, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Have tank pressure but no regulated pressure
This usually happens when the pressure spring in the regulator breaks, sometimes from overtightening the regulator knob. The way it works is that the amount of pressure you put on the regulator spring (by twisting the knob) will be equal to the pressure on the downstream side of the regulator. When the spring breaks, the pressure on the spring is zero and so is your downstream air pressure. You need to replace the regulator.
Jun 07, 2011 | Porter Cable Air Tools & Compressors
I have an Onan 2500 LP generator. What is the red knob for?
That knob should be to bring pressure up and down with 0 being off or the lowest range of the regulator. This regulator is adjustable for different applications apparently.
Jan 21, 2010 | Watts Onan Portable Generator - 4000 ,...
My knob assy (137-0001) keeps popping off and air leaks around the adjustment knob on the top of the assembly.
SOMETIMES YOU CAN TIGHTEN THE OUTSIDE OF THE REGULATOR UP A LITTLE. OR THE REGULATOR IS BAD. OR THE REGULATOR IS SEEING BACK-PRESSURE JUST AS IF IT WAS INSTALLED BACKWARDS. DO YOU HAVE IT CONNECTED TO ANOTHER COMPRESSOR DOWNSTREAM THAT COULD POSSIBLY BE A LITTLE HIGHER PRESSURE AND BLOWING BACK THRU THE REG. HOPE THIS HELPS, JODY
Aug 27, 2009 | Coleman Powermate 11 Gallon Air Compressor
Regulator knob won't turn
Change the whole regulater . this will fix it . Thanx for using fixya
Jun 19, 2009 | Air Tools & Compressors
How do you utilize the air pressure control knob.
Most air pressure regulator knobs work like a "child-proof" cap on a medicine vial.  It has a spring inside that keeps it dis-engaged from the tooth like gears inside.  To turn the knob you must first pull out or push in the knob.  You should feel some resistance from the spring inside.  As you pull, you will feel the knob seat into the "teeth" inside.  Then you can turn the knob and change the air pressure supplied.   Note:  most air regulator valves work in the opposite manner of regular water valves.  Turning the knob clockwise should increase the air pressure... counter clockwise should decrease the pressure.       I hope this solution will bring you success.   Best Regards,  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Sharper Image The 8149SI Stainless Steel Pressure Cooker Logo
83 people viewed this question
Top Sharper Image Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sharper Image Kitchen Appliances - Other Expert? Answer questions, earn points and help others
