Question about Garden
250 sthil weed trimmer burning spark plug with oil
    Sergeant:
  • 340 Answers
Diana reduce the oil mix slightly in the fuel mix and then give it a few goes to reduce the oiling.
Posted on Oct 23, 2013
SOURCE: Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
Posted on May 28, 2008
  • 20 Answers
SOURCE: Craftsman Wee trimmer will only run when tilted on its side.
its your flaot in your little carb
Posted on Mar 24, 2009
  • 57 Answers
SOURCE: Spark plug gap?
.030
Posted on May 18, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Stihl FS 110 brush cutter loop trimmer
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
SPARK PLUG GAP
0.02 in (or)
0.5 mm
Here is a link to the full manual. Spark plug info is on page 50.
HOPE THIS HELPS!
David http://www.stihlusa.com/admin/webcontent/cmsfilelibrary/instructionmanuals/fs120_200_250_manual.pdf
Apr 09, 2014 | Wolfgang Schmuck Total Scooter
250 sthil weed trimmer flywheel magnets .how many magnets on it
Hi diana
You have just one magnet...it is the one that activates the electronics to give fire to the spark plug
Bud
Oct 21, 2013 | Garden
My sthil fs 80 has new carb and new rings. has spark but wont start
Is fuel getting into the cylinder.? Is the spark continuous, check gap between flywheel and ignition module. 0.25 filer guage.
Mar 04, 2013 | Stihl FS 85 Weed Eater
My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
Mar 25, 2012 | Toro& Electric String Trimmer
I put to much oil in my weed eater, lot of blue smoke came out, then it stopped. if i pour some of the oil out and let it cool off will it be ok
should be ok drain oil to correct level remove spark plug clean and dry plug,with plug out crank over to remove oil from cylender,make sure air filter did not get oil soaked if dry reinstall if wet replace. reinstall spark plug and start probably will smoke untill it burns off residual oil in muffler hope this helps
Aug 09, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Just want the gas oil mix for a 25cc weed wacker
if using sthil oil the mix is 50:1 if not then its either 32:1 or 40:1 not to much dif
Jun 08, 2010 | Homelite Mighty Lite Lawn Trimmer
What is the gas and fuel mixture for a homelite st-185 weed eater
If it's not been started for that long, ensure that any remaining crud in the tank and fuel lines is cleaned out before even attempting to start it.
Put in a NEW plug, then mix up some 50:1 mix of unleaded and good synthetic 2-stroke oil (Sthil or similar). This will produce an almost smoke-free exhaust, and won't foul the plug.
If it does start, be prepared for LOTS of smoke initially, as all the old oil from inside the engine burns off.
May 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
