Question about Sony Walkman NWZ-E344 Digital Media Player
Cannot play please connect compliant - Sony Walkman NWZ-E344 Digital Media Player
How do you adjust casio px 300 when connected to ipad2
Newer Casio models that have "class compliant" USB interfaces such as the PX-330 would work (plug and play) since they now have "class compliant" drivers.
Unfortunately PX-300 is an older model that would need specific drivers and Casio only made drivers for Windows PCs.
May 01, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Mp3 player ( sony walkman) says cannot play please connect to compliant software and update license info
when i try to play the music on my mp3 player ( sony walkman ) it says cannot play please connect to compliant software and update license info. i'm not sure how to do this
Aug 04, 2011 | Sony Walkman NW-A808 MP3 Player
Please let me know if Filezilla is HIPAA compliant. If it is not do you know if other FTP programs are? Thank you
FTP clients are typically HIPPA compliant. HIPPA requires that FTP clients be HIPPA compliant through SSL, TLS or SSH/SFTP with at least a 128-bit secure connection. Filezilla supports FTP over SSL/TLS (FTPS) and SSH File Transfer Protocol (SFTP). In other words you are OK to use Filezilla.
Mar 13, 2011 | HIPAA FTP
I get a message saying: "Cannot
What you've encountered is DRM ("Digital Rights Management").
On the computer that holds the file that you are trying to play,
no "license" for that specific file could be found.
Use software like iTunes or Windows Media Player to play the file,
and follow the prompts to go online to pull updated "license" information from the Internet to your computer.
Jan 25, 2011 | Computers & Internet
The device may be incompatible. Remove the device
Hi There,
Check the device connected to the Direct Print Port. Printing photos directly is possible with a PictBridge compliant device or the optional Bluetooth Unit BU-30.
A communication time out occurs if an operation takes too long or if it takes too much time to send data. This may cancel printing. In such cases, disconnect and reconnect the USB cable. When printing from a PictBridge compliant device, depending on the model or brand of your device, you may have to select a PictBridge compliant print mode on the device before connecting it to the machine. You may also have to turn on your device or select Play mode manually after connecting the device to the machine. Perform necessary operations before connecting your device referring to its instruction manual. If the error is still not resolved, check if you can print another photograph.
Mar 07, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Why wont my sony camera work with the polafiod pogo printer
You can print images by connecting the Camera to a PictBridge compliant Printer only.
Please make sure that your Printer is PictBridge compliant.
If your Printer is a PictBridge Compliant, select the USB Connect option in the Camera to PictBridge and then, connect the Camera to the Computer.
The USB Connect option will be located under the Setup2 menu of the Camera.
Dec 25, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Non-HDCP Compliant Error
Jan 06, 2008 | Protron PLTV-32 Television
Hp hd dvd player for desktop wont play hd dvds
I had this problem. Turned out that I was using a DVI cable to connect my monitor to the video card, but my monitor was not HDCP compliant. Most HD-DVD's require the monitor to be HDCP compliant for digital output (i.e. over DVI or HDMI connections). Alternately, you can connect to your monitor via its analog (VGA) input instead, but you won't get HD output. I was able to do this using a VGA cable along with the VGA-DVI adapter for the video card output.
Cyberlink has a tool you can run to see if your system is capable of HD-DVD output. http://www.cyberlink.com/multi/support/bdhd_support/diagnosis.jsp
When I ran it, it gave me a red flag telling me my monitor was not HDCP compliant
Aug 05, 2007 | Pioneer VSX-D511 Receiver
Sony Walkman NWZ-E344 Digital Media Player Logo
20 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
