Compaq Presario SR5610F Athlon 64x2 4800+3GB DDR2 320GB NIVIDIA Geforce 6150 SE Windows Vista,packed up for family relocate,all was well,unpacked,hooked up and now will not turn on,curious blinking green light on back by power cord plug in
  • 2,113 Answers
Check that the mouse and keyboard are not swapped. You may have to unplug it then open it to make sure the ram is seated. It's best to take it out then reseat them one at a time. Check that the graphics card is seated if it is not an onboard graphics. Listen for beep error codes count how many and how many pauses etc. Sometimes that flashing light is an error code we need to know that. One last thing to check is that the hard-drives are plugged in. I have had sata cables come loose off the motherboard easily. Some cabinets have a tamper switch, make sure the door is closed securely. Try to boot up and tell us what you find.
Posted on Oct 21, 2013
4 Suggested Answers
  • 624 Answers
SOURCE: System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Posted on Jan 02, 2007
kikoksky
  • 119 Answers
SOURCE: CPU doesn't turn on!!
    • Power supply light on or flashes Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure: CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
      1. Disconnect everything from the computer, including the power cord.
      2. With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps. NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
      3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America. Performing this step ensures that the voltage switch is engaged and set correctly for your country/region. Figure 4: Voltage selector switch c00517964.jpg Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
      4. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
      5. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it. NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
      6. Remove all attached devices except for keyboard, mouse, and monitor.
      7. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
      8. Check the power switch:
        1. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
          • If the button sticks, it should be replaced or serviced.
          • If the power button does not stick and appears to be functioning, continue using these steps.
        2. With the power cord disconnected, remove the case or side panel.
        3. Follow the wires from the power button on the front of the computer to their connection on the motherboard.
        4. Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard. Figure 5: Power switch connector on Motherboard c00517968.jpg
        5. Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
      9. Find the defective part:
        1. With the power cord disconnected, remove the case or side panel.
        2. Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference. Figure 6: Example of common power connections c00540428.jpg
        3. Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
          • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
          • If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
          • If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
          NOTE: If an electrical storm or power surge has recently occurred, then it is more likely that the power supply, the modem, or motherboard is damaged and requires replacement. If the power supply was damaged due to power outage or storm, this may not be covered under the "act of nature" policy in the warranty statement. Refer to the warranty statement that came with your computer for more information.
Posted on Jun 20, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Compaq Presario S0000/8000 Series hard
is the power supply working have u recently installed a new hard drive or cd rom need to make sure that the wires are securly plugged into the drive and into the board and are plugged in to the drive correctly if this is all ok you may have to get a new drive
Posted on Aug 14, 2008
What to do if my fan is too loud?
replace it. You can buy quieter fans. If the fan was quiet before but got louder, that means it's going to die and you'll want replace it as soon as possible.
Jun 01, 2014 | Compaq Presario SR5610F Athlon 64 X2 4800+...
I need to buy a matherboard for my compaq presario sr 5610 f
I just replaced the motherboard in a Compaq SR5610F because the capacitors were swollen and the computer was flaky: rebooting, losing devices, etc.
I bought an ASRock N68-CGS FX, about $50 shipped. The processor and memory from the Compaq work in it, and the board fits just fine in the case; in addition, you can devote 256 megs of shared memory to video (double the Compaq board). If you want to upgrade later, it will take a number of AMD 3 or 3+ processors, and there are two DDR3 memory slots.
Dec 03, 2012 | HP Compaq Presario SR5610F Desktop PC
Forgot admin password windows vista
You'll need some type of password reset disk to crack the password. I've seen some free ones that you can use whereas you create an ISO image on a CD and boot from it.
Try going to eBay and type in the search "Password Reset". You'll see some for less than $10 that should reset the admin password.
Apr 08, 2012 | Compaq Presario SR5610F Athlon 64 X2 4800+...
Compaq presario sr1920nx--dvd rw lightscribe cannnot read or play dvd, compact disc; cleaned the tray, tried other players: real player, windows media player, sonic player, quicktime player
Assuming it powers on - since it sounds like you can open and close.. check 2 things - 1. run set up - press F1 while booting up for most pc... make sure your dvd drive is detected. if yes, 2 open case and make sure the data cable is connected on drive and the board.
May 19, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
Code purple
this is problem with VGA connectors pins if that is soled properly then the cable of monitor is damaged and need replacement.
if you check cable is fine then replace the Colore IC of monitor
May 11, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
What CD/DVD drives can replace the pre-installed one?
Every single standard IDE unit, you can find one in every computer shops for less than $30.
Jan 16, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
I have a Compaq SR5510f desktop that has intermittent problems with VGA. Now I don't get anything. Cable and display have been verified.
is ur comp booting if yes then there is problem with your monitor cable. if you dont listen beep sound after switiching on ur pc then there is problem with your motherboard.
Jan 13, 2010 | HP COMPAQ Presario SR5510F Athlon 64 X2...
  1. Wire Trak Wire Management Kit for Computer Peripherals, White, Covers 4 ft. Wire Trak Wire Management Kit for Computer Peripherals, White, Covers 4 ft. FASO6PRN5OOW at Sears.com ... wire management system to hide and organize computer ...
    sears.com/shc/s/...& Electronics&sbf=Brand&sbv=Wire Trak - 168k - Cached
  2. Sponsor Results
How to Hide Computer Wires To.OhDeal.com Find a Deal at OhDeal. Computer Wire Covers shopping.yahoo.com Low Prices from Trusted Retailers Shop with Confidence at Yahoo! Sponsor Results How to Hide Computer Wires Find a Deal at OhDeal.To.OhDeal.com Computer Wire Covers Low Prices from Trusted Retailers Shop with Confidence at Yahoo!shopping.yahoo.com
Aug 22, 2009 | Compaq Presario SR5610F Athlon 64 X2 4800+...
Computers & Internet Logo
David Payne
David Payne
