Question about Zoeller 503-0005 Model 503 Home Guard Max Water Powered Emergency Backup Sump Pump
Water powered sump pump does not work, city water goes thru but does not pump water
Why is their about 15 gallons of water built up under my house within a couple of days, but no visible leaks?
Drain pipes might go under the ground. You have slab leak. Plumber will figure it out, or check blue prints of Your house if You have those(will show You "What Where")
Jan 29, 2015 | Plumbing
I installed this pump to company specs and don't understand why it's not working. I brought it back to the place that i purchased it and they got it to work. What am i doing wrong? Municipal water is...
How high does the pump have to lift, in feet from the water in the sump to the highest point of the piping?
While the pump is running, what is your municipal water pressure near the sump pump?
You saw it work in the store, were those conditions different?
Gary
Dec 14, 2010 | Liberty Sump Pump Jet WaterPowered Back up...
My pump won't turn off
If the sump (where you catch the water) was dry, your pump might be air bound.
You say it will not shut off but you dont say if it is pumping. My guess it is is not. You have a local switch, i.e. integral to the pump, right? Not a float switch.
Do this, fill the sump, make sure the switch opening is clear (it works on water pressure) and make sure there is no air trapped inthe pump housing.
I hope this helps.
In my bar situation, I use a float switch and I pump up about 2 feet where the water goes into a stand pipe equipped with a vent. The stand pipe feeds into a hose and leads to a sump elsewhere in the basement where the water is pumped over the side (sorry, that was the sailor in me coming out).
Feb 21, 2010 | Lincoln Lubrication 917 Heavy Duty...
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
The water fills the tank but does not go out of the hose and drain to the sump pump as designed
Check the hose for clog up as well as your sump pump. Have your hose unclogged and let it run. Check the sump pump if this is running. And if it is, and still no water goes out. Open the sump, and check the impeller for defect. Impeller is the one that turns around to push the water out. If it is defective, you must replace it to make it run.
Once you are done, power it up and start it.
Sep 27, 2009 | Haier HDN655E Dehumidifier
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
1/3 hp wayne pedistal sump stoped working
yes there are brushes,, but there is also a shaft that goes thru the tube make sure it is not broke or bent,, it happens,, suggest to get a zoeller submersable pump its the best cast iron, float is attached to the unit, will fit in small pits, only 1 plug needed,, cost for pump 100
Dec 31, 2008 | SPV Wayne Pumps Spv500 1/3hp Cast Iron...
Pump support
Follow these steps to replace a malfunctioning sump pump. If you are starting from scratch and want to put in a completely new sump pump and drain line, you should have a professional plumber do any actual piping unless you have an advaced knowledge of those techniques. Locate the sump pump in your basement. Unplug it to avoid possible electrical shock or personal injury. Find the place to disconnect the pump from the drain line. This is usually either a screw-together type union or a rubber coupling with hose-clamp fastenings. Both are quickly and easily undone. Remove the pump from the pit and allow it to drain for a few minutes. Any plastic piping or fittings that comes from the water outlet opening and goes up to where the pump connected to the drain line needs to be removed and saved to reattach to the new pump. Take the pump with you to your local hardware store, plumbing-supply house or home-improvement center. They can help you pick a replacement that requires the same power source and provides the same drain-line hookups and pumping capabilites. Reattach any piping and fittings in the same way that they were on the old pump. Set the new pump in the pit and reconnect the union. Plug in the pump. You can test the pump by filling the sump pit with buckets of water.
Aug 27, 2008 | Belle Group BHB30 - for 8 gallon Hydraulic...
No water to my Aprilair model 550.
Some sump pump have a safty switch that will not let the hum. come on if the tank is full of water, I,m not sure if this is the type that you have but make sure that the pump is pumping water. Also your humidistat have an internal switch that it should be set to bypass not to power Note: some humidifier have their own power supply the 550 dose not
Jan 26, 2008 | Aprilaire 550 Humidifier
Zoeller 503-0005 Model 503 Home Guard Max Water Powered Emergency Backup Sump Pump Logo
32 people viewed this question
Top Zoeller Plumbing Experts
Paul Nicholson
Gil Shultz
Are you a Zoeller Plumbing Expert? Answer questions, earn points and help others
