Question about Brother HL 5250DN Laser Printer
Width of printout
The printer often prints an output with a narrow column width instead of a standard width. I have tried to reload the drivers without success. How can I get regular width printouts?
  • lizbethmarie May 11, 2010
    I'm having the same issue with my Brother printer. When printing from the web, one page will print out 4-5 pages - each with only a 5x4" space of printed text.
    Can you clarify which part of the settings need to be checked? Everything looks good, but then there are quite a few tabs/preferences.
    Also, the previous poster said he/she had already attempted to reload the drivers with no success, and I can also confirm that problem, even after having used the link given.
    Do you have any other advise? :)
    Genius:
  • 3,587 Answers
Check settings for paper in your panel first..
here's a good link for drivers
check here for fresh set of printer drivers
Posted on Mar 02, 2008
Firmware required
If the the printer will only print 80 column rather than 136, and you know your print job is 136 columns, firstly check the menu settings to ensure the printer is not set to 8inch width. If the printer is set to 8inch width you will not be able to print more than 80 columns.
If you are printing from a Window application you will need to ensure you have the correct paper size (ie 13.6 inch wide) selected in the Application AND the printer driver.
If you are sure the print data is wider than 80 column and the printer menu is set to 136 column and you still are not able to print wider than 80 column it may be necessary to reset the device back to factory settings. (Before doing this I would recommend printing the current settings or make a note of the current settings as you will need to set the device back up again)
To reset the device to factory default;
  1. Start with the printer powered off
  2. Hold down the four grey buttons under the LCD
  3. Keep the four grey buttons held down and power the printer ON
  4. Keep the four grey buttons held down until you see 'Loading Default' of the printer has finished initializing.
Once you have done this you should be able to print 136 column prints.
If you can not I would suspect the data is not greater than 80 columns in width and you would need to check the computer system set up.
Apr 24, 2014 | Tally T2250 Matrix Printer
Missing Column G on print head align printout!
can you please try a test page...and report back what that looks like..
Oct 15, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Using MS Access, I am printing labels to a Zebra 110XiIII printer. The output truncates the label to 2" instead of the 3.5" I have the report page settings saved as. I have been through the setup...
First check printer. Change setting "Print Width" to maximum width, save. Switch off. Hold down pause key while switching on (untill all but power light turns off). the subsequent prints should print across the full width. If this is OK fault is with label format.
If you are using windows printer driver check settings there this can over ride printer settings. If using ZPL the problem is most likely in the label format.
Jul 05, 2011 | Zebra 110XIIII Thermal Label Printer
Auto print head alignment wont work and I need to do a manual alignment. How do I do this for a MP970?
1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette. 2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension. 3. Press the Paper Feed Switch to select the paper source where you have loaded paper. 4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
5. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
6. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
7. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
Mar 01, 2011 | Office Equipment & Supplies
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
May 16, 2010 | Canon MP970 Photo All-In-One InkJet...
Color doesn't match computer monitor colors. Previous printer (canon) colors matched perfectly for the same project.
first, every manufacturer uses different kind of ink and using generic ink can affect output as well.
second, the printers drivers may not be set to the best output type which can addect results. (for example, you are telling the printer to print in draft instead of photo)
another option, is that this is not a photo printer, you may have been using a photo printer before and also the paper may affect your printouts as well, again even though the paper used before was great, it can have a different reaction to brother ink.
lastly, you might need to do color calibration with your software or printer drivers. also do a test print and make sure all the nozzles are firing properly.
Aug 03, 2009 | Brother MFC 490cw Color Inkjet...
After mouse click of print preview, program produces column 20 spaces wide instead of full page portrait width.
I went into properties after the print preview routine presented the print screen for the printer and hit properties reset page and it cleared up.
Mar 24, 2008 | Brother HL-2040 Laser Printer
I can't understand what Fx1170 is printing
Delete print driver and reinstall,with another driver any of the following standard drivers will suit ie FX-1050, EX-1000, FX-286e, FX-100+, FX-100; IBM Proprinter XL, IBM Graphics printer.
How do you have it connected? With normal printer cable or via a usb adapter?
Oct 18, 2007 | Epson FX 1170 Matrix Printer
Page advance problem
print out your menu of the printer and load the IBM Proprinter driver in windows ,your printer default driver is IBM Proprinter this will sort out the problem.you have probably loaded a OKI driver while the printer is set for IBM.Hope this helps.
Dezzi
Oct 16, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
Printing a report
IS IT THROUGH EXCEL THAT YOU WANT TO TAKE THE PRINTOUT FROM? YES - OPEN A FRESH EXCEL SHEET. COPY AND PASTE EVERYTHING INTO THE NEW SHEET. TRY TAKING A PRINTOUT. YES - GOOD. NO - UNINSTALL AND REINSTALL MS OFFICE TRY ANOTHER PRINTOUT. YES - GOOD NO - CONTACT MICROSOFT VENDOR. NOTE : NO PRINTER DISQUALIFIES ANY MS DOCUMENT.THUS ERROR FROM MS VENDOR.
Sep 17, 2007 | HP Deskjet F340 All-In-One Printer
Brother HL 5250DN Laser Printer Logo
76 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
