IR 4570 error code E000716-0010 - Office Equipment & Supplies
  • 126 Answers
SOURCE: Copier does not start workng
E000 to E004 are all to do with the fixing unit. It can be reset but if comes back you will have to check the fuser parts. It has been known to be caused by noise on the mains supply so a filter might keep it away.
***ALWAYS DISCONNECT POWER BEFORE WORKING ON MACHINE****
Since this code has not cleared ( so to speak) you will have to check the; fuser thermister, fuser thermal fuse and the fuser lamp. These can be tested with a multi meter. If any or all of these are defective you have to replace. After replacing defective parts, reconnect power, re-clear code and machine should work.
If code re-appears or does not clear then you are looking at a brd (board) problem and should call for to have a tech come out.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again. You should now be in service mode. Select COPIER and this will give you some options along the top. Select FUNCTION. In the list select CLEAR. From the next list select ERROR and press ok. Then switch off machine and back on at the power socket. If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!!
Posted on Jan 28, 2009
hamzaskilltd
  • 316 Answers
SOURCE: ir 4570 y preseenta un error E 225
CIS light intensity error.
Posted on Jun 07, 2010
SOURCE: ir 4570 error code has come frequently 007
change your power supply.i have the problem also
Posted on Mar 28, 2011
kuldeep_sudh
SOURCE: image runner 4570
i m kuldeep i have 2830 canon plz tell me about the e000100-0001 hurry
Posted on Feb 03, 2012
MUKHTAR
  • 2017 Answers
SOURCE: My photocopy macheni canon ir 4570 keeps on giving the error code e0001-0002
Fuser temperature too high.
Check AC driver board, shorted thermistor. Replace The Main Power Supply PCB Assembly (The part number FM2-0260-000).
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Dec 31, 2012
Error code of canno IR 4570 e000020-0000
Toner is not being delivered where / when needed. See link for other experiences, and resolutions.
Thread What is E000020 0000
Mar 01, 2015 | Cannon Office Equipment & Supplies
E0002250001 canon 4570
Disconnect and than connect the flexible cable,if not okay,replace it
Jun 27, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Jam code 205 in canon Ir 4570
Try to open up the copier where usually the paper goes through and check for any remains of bits of paper.
PS: on the screen shows which side of the printer has to be opened.
Feb 24, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Help what is this code e000191-000
Jam Code 205 in Ir-4570 solved by replacing sensor PS-59 Arm
Oct 08, 2012 | Canon Imagerunner 4570 Copier
Error code E000042-0001 canon ir 3570/4570
When do you encounter this error? When you try to boot the system?
Jun 02, 2012 | Dell Computers & Internet
Canon copier 4570 error code e000007-0000
canon ir 4570 error solution for Code E000007-0000
Nov 25, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Canon ImageRunner 4570 gives me an error code:E000001-0010
A E 000 code is a fuser ass'y problem. It will need to be rest in service mode...
Mar 04, 2008 | Canon imageRUNNER 4570 Copier
jasbo
jasbo
