Question about MSI P4MAM2-V 400/533 MHZ FSB Socket 478 All-In-One Prescott Motherboard (MBSK478MSP4MAM2V)
M845gl 400/533 mhz - MSI P4MAM2-V 400/533 MHZ FSB Socket 478 All-In-One Prescott Motherboard (MBSK478MSP4MAM2V)
Tabla de frecuencias
CB Radio Channels (FCC)[32] Channel Frequency Channel Frequency Channel Frequency Channel Frequency 1 26.965 MHz 11 27.085 MHz 21 27.215 MHz 31 27.315 MHz 2 26.975 MHz 12 27.105 MHz 22 27.225 MHz 32 27.325 MHz 3 26.985 MHz 13 27.115 MHz 23 27.255 MHz 33 27.335 MHz 4 27.005 MHz 14 27.125 MHz 24 27.235 MHz 34 27.345 MHz 5 27.015 MHz 15 27.135 MHz 25 27.245 MHz 35 27.355 MHz 6 27.025 MHz 16 27.155 MHz 26 27.265 MHz 36 27.365 MHz 7 27.035 MHz 17 27.165 MHz 27 27.275 MHz 37 27.375 MHz 8 27.055 MHz 18 27.175 MHz 28 27.285 MHz 38 27.385 MHz 9 27.065 MHz 19 27.185 MHz 29 27.295 MHz 39 27.395 MHz 10 27.075 MHz 20 27.205 MHz 30 27.305 MHz 40 27.405 MHz
Oct 18, 2013 | Connex 3300 240-Channels Base CB Radio
I dont have mother board driver for system model awrdacpi
The Intel® Desktop Board D915GAG supports one Intel processor in an LGA775 socket. See the table below for a complete list of supported processors.
Processors not specifically listed by type and rated speed can have requirements that are not supported by the design of the desktop board. Use of unsupported processors can result in improper operation, damage to the desktop board or processor, or reduced product life.
Processor Family System Bus Frequency L2 Cache Size BIOS Version Intel® Pentium® 4 800 MHz 2 MB 0391 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0477 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0475 or greater
533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater
DOWNLOAD LINK IS GIVEN BELOW...........
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22Intel+Desktop+Board+D915GAG%22
Sep 22, 2011 | Intel D915GAG Socket 775 Motherboard -...
Hi i have pc with motherboard M845GL mother board, when i powering on, nothing happen means no processor even runs, my smps is alright. what are the problem may be ..?
Hi, Mayur here. To fixed this issue first check the power code is working or not. Get a new power code. Then remove RAM chip clean the RAM chip and plugged it again. Then start your system It works. Try it.
Sep 02, 2011 | Computers & Internet
Looking to find the frequenecies of the upper and lower channels
  • Hi I can help.
  • For the Grant 40 channel CB there are 40 frequencies I will list below.
  • When you refer to the upper and lower channels for this raidio you must mean USB (Upper Side Band) and LSB (lower side band).
  • This is called single side band modulation which is to say the the carrier is removed from the upper or lower sideband depending on which your pick and the signal goes farther on less power.
  • So the upper and lower side bands are the same frequency just upper side band or lower sideband.
  1. 26.965 MHz 21. 27.215 MHz
  2. 26.975 MHz 22. 27.225 MHz
  3. 26.985 MHz 23. 27.255 MHz
  4. 27.005 MHz 24. 27.235 MHz
  5. 27.015 MHz 25. 27.245 MHz
  6. 27.025 MHz 26. 27.265 MHz
  7. 27.035 MHz 27. 27.275 MHz
  8. 27.055 MHz 28. 27.285 MHz
  9. 27.065 MHz 29. 27.295 MHz
  10. 27.075 MHz 30. 27.305 MHz
  11. 27.085 MHz 31. 27.315 MHz
  12. 27.105 MHz 32. 27.325 MHz
  13. 27.115 MHz 33. 27.335 MHz
  14. 27.125 MHz 34. 27.345 MHz
  15. 27.135 MHz 35. 27.355 MHz
  16. 27.155 MHz 36. 27.365 MHz
  17. 27.165 MHz 37. 27.375 MHz
  18. 27.175 MHz 38. 27.385 MHz
  19. 27.185 MHz 39. 27.395 MHz
  20. 27.205 MHz 40. 27.405 MHz.
  • If you have any comment please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
Processor upgrade
f you want model #s, Dell support will furnish them. However, the GX260 is a P4/400,533 FSB system, so a 2.4 would not pose a problem.
I've installed 2.8 before with no worries.
Good luck
Nov 07, 2007 | Dell OptiPlex GX260 PC Desktop
MSI P4MAM2-V 400/533 MHZ FSB Socket 478 All-In-One Prescott Motherboard (MBSK478MSP4MAM2V) Logo
67 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
