Question about Philips 9P5544C 55" Rear Projection Television
Horizontal bow and shadow
My 55? projection TV top of picture is bowing down and the bottom is bowing up. There is also a very pronounced shadow in the picture. I have not been able to find a service manual for this model#.
  • meoff Oct 04, 2007
    If someone knows were I can get a service manual that would help. I replaced both ICs #STK392-110 and checked all resistors and 3 fuses, they are all good. When I go into setup to align the cross hairs I don?t see any blue at all, the word blue does not even show up in the text line. The red shows up brightly but I cant move the cross hairs. What do I look at next?
  • meoff Oct 30, 2007
    Terryfic
    I’m not shire how this site works but I added a comment a few days ago about putting the convergence board in another TV and it works just fine. My problem is not the convergence board
  • Philips Master
  • 3,459 Answers
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try www.magnavoxhelp.com - They have instructions and kits on their site.
Posted on Jul 04, 2008
  • Edward
    Edward Dec 18, 2008
    If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
    Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
    (Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
    Symptom: No Audio or Video but power light is on
    Symptom: Audio works but no Video. Power light still work
    Symptom: No Video. Audio is intermittent. Power light still works
    Genius:
  • 1,694 Answers
Replace convergence IC's--then re-check convergence alignment in servicer mode,if necessary.
Posted on Oct 03, 2007
  • Vista Electronics Oct 29, 2007
    MEOFF,
      Sounds like your problems are self-inflicted! I've been there
    many times in my 35 year career!!
    1) were the correct parts installed-- STK392-110 or 120???
    2)After soldered in, did you confirm with your eyes and a meter
      that you did not short two or more pins together? Cross check
    by comparing one IC to the other,pin for pin.
    3)Did you use first quality,excellent OEM or better IC's?For
     instance,STK392-110 subs to STK394-160E in Hitachi, so that
     would be the best choice.
    4)Did you use cheap,generic replacements? They can fail
       on contact or within a short time of use!!
                 Please let me know,I'm very interested!.......T.
  • Vista Electronics Oct 30, 2007
    Sorry to bark up the wrong tree with the wrong dog!
    I missed your comment about the board swap!
    Obviously, we must look elsewhere----how about the power supply?--Check all fuse devices,pico fuses,etc......T.
    Probably need service lit. after that.....1-800-851-8885.??
3 Suggested Answers
SOURCE:
  • 105 Answers
SOURCE: 9p5544c102 Horizontal bow
is the blu crt even turning on
Posted on Oct 13, 2007
skippy101
  • 143 Answers
lookin the main power supply check for pico fuses somtimes they go bad, turn up your sreen voltage on your blue look see what kind of pic it gives you
Posted on Nov 03, 2007
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
ok meoff check the convergence circuit. shadow in the picture is defective convergence circuit... replace a new.
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
Ws55809 tv picture bows at top and bottom. Also has shadows. Is it the bulb and where do I get one.
You have a convergence problem. The 3 picture tubes are fine. The small signal module needs reworked. The board with all the rca jacks.
Nov 29, 2009 | Mitsubishi WS-55809 55" Rear Projection...
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Mitsubishi TV Picture Bowing
You will find a very good guide here and here to fix your TV.
This might not be a DIY if you do not feel comfortable. The repair shops charge about $350.00 to $400.00 for this type of repair.
Apr 19, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bow at top and bottom of the screen
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jan 10, 2007 | Samsung HCM5525W 55" Rear Projection...
Philips 9P5544C 55" Rear Projection Television Logo
253 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
