Question about GE JEM31 Microwave Oven
Spacemaker II Microwave problem
Unit will not shut off unless door is open or unplugged
  • GE Master
  • 9,098 Answers
Quite often this is due to a bad door switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
Microwave wii not shut off unless you open the door and sometimes starta when you shut the door.
Sounds like one of the door switches is shorted. Check all three for proper operation with power off. WARNING: Microwaves contain lethal voltage levels can be more than 4000V, more then enough to kill you! BEFORE doing an work on them, unplug from power and discharge the capacitors. If you don't know what you're doing its better to leave it alone and get it professionally serviced.
Feb 27, 2015 | GE Profile Spacemaker Over-the-Range...
My GE Spacemaker (JVM1331) will not turn off when door is shut. Have had to unplug unit. This unit is 15 years old.
one or more door swiches need replacing maybe be three in all but likely one is the cause not sure which one without testing with electrical meter
Oct 21, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacesmaker model #JVM1440BH04 that came on by itself and can't be shut off unless the door is opened. It does not seem to be cooking since nothing heats up unless the cook start buttons are...
The problem is in one of the door switches, "it is defective" this is a highly dangerous situation and should be checked immediately, the microwave oven should unplugged until a appliance repairman looks at it.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker (HVM1540) will not turn off. Often when we use it and open the door to get food out, then we reclose the door and it continues to run. Even after hitting Clear/Off it continues to run...
Ok I have the same model and mine was doing the same thing. Apparently this model has a reputation of problems with the control board. I played with mine for hours and here's what finally worked: unplug the unit (or shut off the breaker--whichever's easier for you), take a dry cloth and wipe the door latches and control board clean of any residue. Then with the door still open, gently jiggle the control board by firmly grasping with your hand. Power up your unit again. This worked for me. The control board is really fussy and should be clean and free of any dust or residue. I notice this happens again when it gets dirty so I repeat the process and it's been working.....so far!!!
Jan 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our spacemaker GE microwave somtimes will not shut off. the only way to get that to happen is to unplug it . It does not happen allthe time and seems most frequet when we open the door to check something...
Turn off the breaker in your electric box and then turn it back on, to see if the controls reset. see if that helps. Otherwise you may have to leave the door open until you can have a repair person check out your microwave.
Check out the manufacturers web site, and see if you unit has a recall.
Good luck.
Dec 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge pvm2070 shut off and now will not come on
My PVM2070 Spacemaker Microwave quit working & its DEAD. I checked circuit braker, unplugged unit, checked power is ok, open/shut door, pushed very sensor buttons; its DEAD. Help??
Nov 09, 2009 | GE PVM2070SMSS Microwave Oven
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave
maybe the problem is in the door latch switch try to replace the switch going to lights or bulb.
Jun 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JEM31 Microwave Oven Logo
195 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
