Question about Frigidaire Freezers
I have a GLFU1467FW0 upright freezer with the control panel on the door. The wire going into the bottom of the door is loose causing the control to panel to improperly function. Does entire door have to be replaced?
Sea Breeze
  • 4654 Answers
SOURCE: GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Posted on Oct 24, 2007
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
mumma_1
  • 903 Answers
SOURCE: how to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Posted on Dec 08, 2008
aborcass
  • 2651 Answers
SOURCE: Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Posted on Jan 14, 2009
cactus bob
  • 267 Answers
SOURCE: Kenmore Upright freezer needs cleaning under bottom shelf
most of the sears freezers . lift up on the shelf that will unlock it then slide it left or right ( it may move a little hard ) that will unlock the other side , lift and remove ( one side at a time ) ... you will see its not that hard , its just hard to put it in words .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 04, 2009
I have the GLFU1467FW0 model Frigidaire freezer, and the temperature alarm won't stop going off. How do I flip it off for good? Pressing the alarm reset button does nothing.
Hello Whywhywhywhyshame, thank you for your post!
Based off the information you have provided the temperature alarm on your Frigidaire freezer will not stop going off. This sounds like a possible problem with your sensor or control panel. I would recommend performing a reset on your freezer and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not help resolve your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Apr 06, 2015 | Frigidaire Freezers
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a 2007 model 253.264 upright Kenmore self-defrosting freezer. The control panel on the front door stopped working. No temperature reading and no way to adjust controls. The freezer is still
I have one out in the yard that is doing the very same thing. Works good but the door display is out. I looked underneath and all of the wires seem to be connected. The main control board is on the bottom as well. The battery is also new. You must have a broken wire between that control and the main board below. I imagine it has something to do the the connector that goes through the door.
Sep 21, 2012 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Ice forms at the bottom very solidly Model: Maytag MQU1656BEW 15.7 cu. ft. Upright Freezer with auto defrust
check for a bad/ loose/dirty gasket on the bottom side ofn the door. check your drainage line for clogging on the defrost system for back up
Jul 20, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Replaced gasket twice; still ices up around door.
If you replaced your door gasket and your absolutely sure that its sealing properly, then it might not be coming from your door. Ice builds up when warm air enters the fridge and the condensation freezes inside the freezer. The biggest suspect for warm air entering into the fridge is a faulty door gasket. However there can be another cause. If you remove the back panel of your freezer you should be exposed with the wires that come into the freezer and power the different components inside. The entrance point were the wires come in is insulated with a type of clay that prevents moisture from entering. However if this clay becomes loose it is possible for moisture to enter and start icing up. If you can remove the panel yourself safely without hurting yourself or damaging the fridge i recommand trying this first. If you don't feel comfortable doing this i recommand having a service technician taking a look at it. Hope this helps.
James Memije
Head Technician
Accufix Appliance Service Centre
Oct 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
What could be causing my 7 year old upright Frigidaire Model FFU21K2CW0 Freezer to NOT freeze? The inside (of the compartment) coils feel cold, the seal is good, but the ice cream is VERY soft. The...
Your freezer is probably running constantly as well. Lift the bottom vent panel (the one with all the holes in it) and look at the bottom of the back panel. There should be a half inch gap for the cold air return. If you see a solid wall of ice in that gap your coils have frozen over. You need to clean out the freezer and defrost it. Look in the back near the compressor. If your model does not have a drain plug in the bottom then you need to leave the door open and mop up the water as it melts off the coils from the inside. If you can, wheel it outside on a dolly and let it defrost where it can drain on its own. After you are sure it is totally defrosted, plug it back in at a control setting of 5 for at least 4 hours, preferrably overnight, and check the temp. Setting the freezer at 7 will encourage ice buildup. Your problem may be a bad defrost timer, which your local appliance parts store may have.
Aug 03, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Mu upright freezer door seal was loose and it is leaking from door would this cause domw food to thaw and can it be fixed
a leaking gasket can cause food to thaw and it can be fixed if a new gasket is avaliable from local appliance parts place..the gasket is held on by the liner which is removed by gently lifting the gasket and removing the screws..the reverse to install the new gasket
Sep 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
21 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
