E60 error baumatic
Baumatic machine eror e60 wont spin
2 Suggested Answers
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
Supra washing machine E60 error
E60
Washing machine motor does not work - no drum action or rotation or not spinning
  • Check motor wiring
  • Check motor
  • Check electronic controller
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3337-zanussi-zwg-range-washing-machine-error-codes
May 03, 2016 | Supra Washing Machines
Machine stops during the spin, especially with heavier loads.
Maybe you overload your washing machine. Minimize your washing machine usage to avoid stopping during the spin.
Aug 23, 2015 | Baumatic Washing Machines
Error code e60 zwg 1140m
Heating time out. Could be heating element.
Dado
Sep 12, 2014 | Zanussi Washing Machines
Just hada brief power flash. Washing machinbe was on. Now just keeps beeping with E60 lfashing on the screen. Not continuing cycle. Can't open door. Can;t re set
The E60 is not listed but it means the cycle was interrupted due to a fault with the motor.
You don't provide many details about what is happening or when the code is displayed.
Try to run a drain and spin cycle and see if the motor will turn.
The E60 error most likely means there is a problem with the motor.
Mar 13, 2011 | Washing Machines
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
Error code E60 Zanuusi Washing machine
Error code E60 Fix... Press the reset button in for 5 seconds. The computer board needs resetting. You can also try to reset it by switching the machine off and unplugging it to allow any residual charge to clear from the memory chip. The next step is to clean out the filter at the front - remember to empty the water out first. After a couple of hours, switch the machine on, press reset and then spin to empty any remaining water. If the problem still persists then it is due to Fault in washing NTC sensor, wiring or main PCB.
Nov 29, 2009 | Washing Machines
Baumatic washer draining but not spinning
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Sep 05, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic washing m/c btwm4
check that the drain filter is clear, if thats ok its probably going to be the electronic module at fault.
Nov 25, 2008 | Baumatic BTWM4 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
