Question about Dryers
Indesit idc 75 how do u change the belt - Dryers
2 Suggested Answers
gkat262
SOURCE: indesit tumble dryer IDC 75 making knocking noise
drum support rollers is the problem as i just opened mine up and you can see and hear the noise, so i found a plastic ring and snipped it to make it as a clip and this has reduced the noise for now by placing it on the near side but will look into replacing support rollers asap as its just a temp fix till i order parts.
Posted on Jul 15, 2012
Why does belt keep coming off when spinning?
Sadly, this is almost certainly drum bearings worn out and the drum spins off centre, causing the belt to come adrift (I'm guessing your spin cycle has become significantly noisier recently). Worse news I'm afraid, the IWC6125 uses a sealed, non serviceable drum, so this is really an uneconomical repair that will cost around 60%-75% of the cost of the machine when new
Sep 06, 2015 | Indesit IWC6125 Front Load Washing Machine
Where is the IDC front sensor in konica minolata C450
Located under the transfer belt, which mean the belt has to be removed then must know witch accurator to depress to open the cover that protect them when the belt is not installed. One is to the rear the other is to the front. looking from thee right side of the machine
Jun 03, 2014 | Konica Minolta bizhub Office Equipment &...
Water not going into condenser drawer leaking underneath indesit IDC 85
hello
have you cleaned the condensing unit out lately? they are usually located somewhere at the bottom behind a panel. they need washing out every month or so.
Apr 06, 2014 | Dryers
How can solve error p 5 idc sensor in konica minolta bizhub c450
P5 front IDC sensor failure.Wipe clean the surface of the transfer belt if it is dirty with a soft cloth or change the transfer belt unit is damaged.Reinstall or reconnect IDC sensor shutter or connector for every color unit and clean the sensors when vacuum cleaner after remove the all imaging units and the transfer belt unit.
Mar 25, 2014 | Konica Minolta bizhub Office Equipment &...
Error p 5 konica milnolta bizhub c450
IDC sensors are located under the transfer belt on the right sid eof the machine. Belt must be removed to clean sensors. Once belt is removed sensors are located on a black plastic frame and have slideable covers that can be moved by hand to clean sensors. There are 2 sensors one machine front and one machine rear.
Mar 01, 2014 | Konica Minolta bizhub Office Equipment &...
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
Indesit tumble dryer IDC 75 making knocking noise
the only things that will cause this to happen are the rollers or the blowewr wheel.
May 18, 2012 | Dryers
Hi I have an indesit IDC 75 tumble dryer which trips the RCD when I switch on. If I disconnect two wires (one orange and one White) from a small connector on the front of the drum it works ok. Do you know...
had the same problem open the door put your head in and you will see a heater sensor my one was covered in fluff cleaned now working fine
May 30, 2011 | Dryers
Fitted a new belt to indesit is60v tumble dryer, worked for a few seconds and now does'nt work at all, just makes a buzing sound?
Check that the belt has not fallen off ...does the drum turn by hand easy if so then its fallen off .Motor could also have jammed....
Feb 10, 2011 | Dryers
Dryers Logo
14 people viewed this question
Top Dryers Experts
