Question about Boston Acoustics Horizon iDS3 plus Powered speaker system with wireless subwoofer designed for i (HIDS3BPLUS)
Boston ids3 no sound - Boston Acoustics Horizon iDS3 plus Powered speaker system with wireless subwoofer designed for i (HIDS3BPLUS)
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
I have boston ba 735 speakers i am using a new pc with windows 7 a presonus firemobile setup. I can get no sound out of the boston speakers. They are lit up when connected. I am able to record sound via...
click start control panel hardware and sound manage audio devices playback then select speakers you will se a list configure test disable set as default show disabled show diconnected.right click on speakers make sure they are enabled also select the recording tab you will see microphone midi right click on microphone and midi make sure ticks are in boxes show disabled devices and show disconnected devices
hope this helps
Jun 27, 2011 | Boston Acoustics BA735 Computer Speakers
The small speakers produce sound but the sub
I have Boston BA745 speakers and want to use them with my new HP Pavillion Elite HPE computer. How do I get them to work?
Dec 27, 2009 | Boston Acoustics BA745 Computer Speakers
I have a Boston BA745 sys where can I download a
you should'nt need a driver for the speakers, you just plug it in the sound port, unless you dont have a sound card driver, let me know weather you need a sound card driver , cheers
Dec 12, 2009 | Boston Acoustics BA745 Computer Speakers
Hi. have recently changed computer systems. My boston 2.1 system , from 2001, however has a double 3.5mm jack plug, whereas the sound card in new computer takes a treble 3.5mm jack plug. The speaker system...
Hi John!
Lucky you there are adapters for almost everything according to sound:) so you can easy buy an adapter that solves your problem,
Go to a good store that is specialist on "sounds"/"HiFi" and they will sell you the adapter you need, No need to get rid of the boston system.
Good luck to you
Nic
Nov 12, 2009 | Boston Acoustics MicroMedia Computer...
My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
No sound from rear speakers Boston Acoustics BA 7800
check whether the wire is connected properly on both the ends
Aug 08, 2009 | Boston Acoustics (BA7800) Computer...
Boston ba635 driver
There is no such thing as drivers for your speaker system, if you are experiencing no sound you will want to probably get the drivers for your sound card. Please post a new question with your sound card and a request for drivers if possible.
Please help me out by rating my response 4 thumbs if you cold! =)
Thanks
Tim
Jul 16, 2009 | Boston Acoustics MicroMedia Computer...
Will my boston accoustics ba735 speakers work with a dell laptop?
We also have a Gateway Computer purchased in 2001 with the Boston Digitanl BA735 speakers. We ran into a similar problem when we upgraded from Windows ME to Windows XP, with no sound after the upgrade. After consulting with computer stores and "Geek Squad", it was finally determined that Windows XP set the speakers for analog not digital. Once that was reset, our sound returned. Hope this works for you.
Mollys Mom
Jan 02, 2009 | Boston Acoustics BA735 Computer Speakers
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
Boston Acoustics Horizon iDS3 plus Powered speaker system with wireless subwoofer  designed for i (HIDS3BPLUS) Logo
48 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
