Sony tv keeps changing channel
When we change channels it does not remain on one channel ir runs thro all the channels
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
It sounds that the main system control memory IC is faulty.
Posted on Oct 21, 2013
5 Suggested Answers
  • 192 Answers
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
romsky79
  • 822 Answers
SOURCE: Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
Posted on May 29, 2009
  • 304 Answers
SOURCE: My tv keeps turning off and changing channels.
You have a bad Main bd.
Posted on Jul 17, 2009
pabloloco
  • 2335 Answers
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Posted on Dec 26, 2009
Hi. I have a sony LF-X1 12.1 Locationfree tv and the touch screen has stopped working. I am not able to change channels. can you help?
Same problem here...
I use a IR remote to change channels and I am trying to plug a USB keyboard to go to SETUP and than Recalibrate the stylus...
Let me know if it works for you at ggauthier55@hotmail.com
Mar 18, 2011 | Sony LF-X1 12.1" LocationFree TV...
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Tv is stuck on one channel and remote doesn't change channel
ir the tv isnt a dtv ready only you see the channel 3.if the tv is dtv ready run autoprogram
Apr 26, 2010 | Sansui Televison & Video
I have a sony kp-57wv600 57 inch tv. and the channel button does not work. The channel button on the tv and the remote does not work. When I hit the channel button all that happens is the tv flickers but...
The first thing to do is to rescan for channels. If for some reason the channel memory got wiped out, there could be no other "available" channels to change to. The "flicker" you see is the TV changing to the same channel. Try the rescan and update this if that does not resolve the problem. Let's eliminate the simple stuff first. If the rescan DOES resolve the problem, please update this with that information as well and we will try to find out what cleared out the channel memory.
Thanks,
Dan
Aug 08, 2009 | Sony KP-57WV600 57" Rear Projection...
TV WON'T WORK
its an rca this is a known problem. recently on ghost story cuz owners thought house was haunted. no the tvs ir is so sensitive it will power on and change channels on its own if someone enters the room. friend probably new this was happening. there is a fix but must be authorized repair center.
Jun 03, 2009 | RCA F36650 36" TV
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
Changing channels
Sony products are the most commonly supported in the field of IR universal remotes. You may find that your cable box remote can be set to send sony codes or that a generic universal remote can be picked up for a couple bucks from best buy or even sometimes a 7-11
May 17, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony trinitron tv KV-32LS36U changing channels
You may have a control button sticking either on your remote or on the front panel of your set. I have run in to this on several sets. When this happens, some really strange things will happen including problems like you're having. Stargazer
Jun 13, 2007 | GE 32GT660 32" TV
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
