Question about Kenmore Dishwashers
Kenmore 16485 will not fill with water - Kenmore Dishwashers
  • 2,113 Answers
Did you check that the water valve (usually under the sink) that feeds the dishwasher is turned on
Posted on Oct 21, 2013
Testimonial: "water valve is open, can hear timer running, but no water getting thru inlet valve."
  • Wayne White
    Wayne White Oct 21, 2013
    The water valve is open. When diwasher is turned on, timer starts but water is not getting through inlet valve. Maybe a bad inlet valve?
  • Wayne White
    Wayne White Apr 21, 2014
    My problem was in fact a bad inlet valve. This is an old dishwasher and Sears showed the valve as a discontinued part. I located the part online at partsdirect.com for a reasonable price and it took care of my problem.
Water not filling up kenmore washer model number11024642300
The most common thing that causes the washer not to fill up with water is the water inlet valve. If this valve has power to it when it's supposed to be filling with water, and you have adequate water supply to the washer, then the washer should be filling with water. The part number for the replacement valve is 285805.
Mar 22, 2012 | Kenmore Washing Machines
I have a kenmore model 110.28922790. It will not stop filling with water. What would be the likely cause?
the water pressure/level fill switch under the control panel is defective,it uses water level/pressure per you setting on the control panel for wash load size to fill it to the set level,then start the washing cycle after it fills
Mar 23, 2011 | Kenmore Washing Machines
Kenmore hd 80 series,extra capacity plus. cold water will not fill tub?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 23, 2011 | Kenmore Washing Machines
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
Kenmore washer fills with water
You may have a bad lid switch. Need the model to check for you. Thanks
Dec 01, 2009 | Kenmore Washing Machines
Kenmore washer 90 series will not fill up with water
You can shut off the water, then remove the hoses to see if the screens on the fill valve are gunked up. This is much easier to do than to replace the valve. I think you'll have sucess on that route :)
Aug 09, 2009 | Kenmore Washing Machines
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Dishwashers Logo
44 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
