Question about Garden
Reg gas in 2 cycle chain saw - Garden
  • 7,482 Answers
Hi wiley
Your chainsaw is probably good for the junk heap if it is ceased or locked up.
If you can still pull it thru, drain out all the non-oil gas and refill with gas and oil mixed to the normal mixing for your chainsaw.
Give it a crank and hopefully all will be good to go for a while
Bud
Posted on Oct 21, 2013
Editor925
  • 285 Answers
SOURCE: 2 cycle oil to gas mixture ratio
40:1 for a McCulloch 3214.
Posted on Jun 24, 2009
  • 15 Answers
SOURCE: Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Posted on Feb 09, 2010
  • 3 Answers
SOURCE: Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
Posted on May 26, 2010
  • 553 Answers
SOURCE: gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Posted on Jun 12, 2010
SOURCE: I have a craftsman gas chain saw model 358.352180....
Make sure you drain the oil when storing your saw. That's because the saw is designed to supply a generous amount of oil to the chain and bar.
Posted on Jun 18, 2010
Chain gas saw
If you are looking for the gas/oil ratio, McCulloch recommends 50/1 gas/2cycle oil mixture.
Oct 05, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
What type of GAS and OIL need for the chain saw?
Hi gjoun...
You will need "Chain and Bar" oil to lube the chain and bar. Special oil made just to lubricate the chain and bar as the chain is running.
For the engine you can use the low grade of gasoline...and 2 cycle oil.
Fuel mix...50 to 1 = 1pint of 2 cycle oil to 6 gallons of gasoline.
Please take time to rate me
Sep 19, 2011 | Homelite ZR10926 16 Chain Saw
What kind of motor oil is used in the chain saw. what kind of oil is used for the chain.
Hi justariblake...
You did not say if your chain saw was 2 or 4 cycle...
If it is 2 cycle...you will mix 2 cylce oil with gas at a ratio of 50:1...one pint 2 cycle oil per 6 gallons of gasoline.
If it is 4 cycle then you will use 10w30
On the bar and chain you will use bar and chain oil (a special oil made for chain saws)
Aug 19, 2011 | Poulan Garden
On a gas chain saw, do you mix the gas
there is usually a fuel/oil ratio (i think yours is 50:1) you must buy the 2 cycle oil and mix it with gas at the ratio reccommended by the manufacture. the bottle may say 6 oz per 1 gallon = 50:1 So 1 bottle of 2 cycle oil for every gallon of gas. mix them in a proper fuel can. then let the cutting begin.
Mar 17, 2011 | Homelite ZR10926 16 Chain Saw
Do you run straight gas through it
No, gas chain saws use a 2 cycle oil gas mix, it should say on the chain saw fill or on a bottle of 2 cycle oil the mix or ratio of oil to gas mix.
Dec 03, 2010 | Garden
Gas/oil ratio for fuel in a poulan pro 46cc engine
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
What solution do you put in the gas of a chain saw
The oil they gave you was to mix with the gas. The chainsaw has a 2 cycle motor that requires two cycle oil to be mixed with the gas.
May 06, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
