Question about Husqvarna Garden
Problem starting My YTH2454 has developed a problem starting. It will make a clicking sound or no sound at all when I turn the key. I have replaced the battery and electric relay between battery and starter. I can jump it with a cable connecting the battery directly to the starter with the key on. Is the starter bad?
  • Husqvarna Master
  • 1,169 Answers
If you jumping direct to the starter and it is starting then the is okay and there is another problem in the circuit.
Need the other numbers on the id tag to look-up the wiring for further diagnosis.
Posted on Oct 21, 2013
SOURCE: FARMTRAC 665 DTC
Try changing the ignition switch.
Posted on Apr 20, 2009
  • 251 Answers
SOURCE: Dead starter, I think!
it does sound as though your starter is dead , depending on the make/model of starter you might be able to get a replacement carbon brush pack which will save a lot of money , please post the starter /engine details
Posted on Oct 25, 2009
brado83
  • 106 Answers
SOURCE: the mower will not start
hello can you hear a clicking noise this noise should come from the starter solinoid (A heavy duty switch with two big poles and one smaller one) it is common for these to burn out a quick test is to take 12v off the battery and put it on the little pole on the starter solinoid this should trigger the solinoid...
If this starts your tractor then there is a problem with the fuses or wiring before the solinoid
Regards
Brad
Posted on Jan 01, 2010
  • 53 Answers
SOURCE: will not start. Replaced battery thinking it was
make sure all connections are CLEAN first. Especially if your battery wire has a plug and socket connect at some point. To test the starter make sure you can tell which leads are which ( - Black = negative or + Red = positive) Don't guess or assume. MAKE SURE. Then you can test the tractor starter with your car battery and a pair of jumper cables. But (Und this is a big but!) Make sure the tractor battery is 12Volts and not 6 volts!If it is 6 volt you can't test it with your car battery.
Posted on May 06, 2010
wireguy212
  • 1627 Answers
SOURCE: riding mower-starter relay clicks-no start even with jumpers.
The frame of the tractor is the same thing that starter grounds to,so yes ,put the ground any where on the frame or engine block to test the starter.An easier way to test everything is to cross over the large posts on the solenoid with a screwdriver and if it turns then the starter is not the problem.Then you will need to put power from the post on the solenoid that has the battery positive connected to it ,to the post on the solenoid that should come live with the key,if it starts then then you likely need an ignition switch if not you need the solenoid.
Posted on May 31, 2010
Testimonial: "thankyou for your expert help, I feel a lot more confident now about the problem.will run the system checks you described. thanks again, grump."
Question:On the Husqvarna Model No. YTH2454, the battery will not charge
more likely to be the alternator, if you know how to check voltsge or take to a technician to be check for is located deep inside the engine, or send to me the mengine make and model to give you a step by step guide
Apr 05, 2014 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Will not start, battery is new, it just clicks and nothing. turn it off, try again and nothing, try again and it starts
Try cleaning and tightening well the battery connections along with the battery wires to the solenoid and starter motor.
Bad connections and low voltage of 12 volts can result in this anomaly.
Jun 12, 2017 | 1997 Lexus ES 300
Clicking sound but engine won't start
This actually does sound like the battery is low on charge. A battery which is quite low on charge will still light the headlights and run many other electrical accessories, but will not engage the starter (which requires much more power than other accessories).
I would start by making sure that an electrical device, such as interior lights, glove box lights, trunk light or something else has not been left on. Then carefully jump start the engine. It is also possible that the battery might need to be replaced for not holding a charge.
Nov 25, 2012 | 2006 Subaru Outback
Wont start but makes weird stuttering sound
Sounds like the battery is low on charge or is in need of replacement in most cases.
I would not change the starter until trying a new battery that is fully charged.
Dec 19, 2010 | 2005 Mercedes-Benz C-Class
2003 Town and Country start problems
yes it sounds like the starter is bad,you have to keep on turning the key and you hear a click everytime you turn the key,replace the starter that should solve that problem,also make sure your battery connections are tight and clean.
Feb 27, 2010 | 2003 Chrysler Town & Country
I posted this a little bit ago but forgot to mention The car would not crank. I started the car and it just dies. Wlould not start or even crank. When I put the key in the egnition (and NOT turning the...
check to make sure yu have 12v at the battery, once you do turn the ignition to start, if nothing, check the fuse and relays that control ignition, if all is good then the click sound is coming from the starter, have the solenoid replace.
Jul 31, 2009 | Saturn SL Cars & Trucks
1998 Celica engine won't start, rapid clicking audible
sounds like you are on the right track, the battery you have in it has done well to last that long but it sounds like a fell cells have decided to call it quits
May 26, 2009 | 1998 Toyota Celica
Click, Click, before it starts
sounds like starter relay or solenoid.
Aug 07, 2008 | 1996 Isuzu Rodeo
Starter fails to start.
I'm having the same problem. The dealership keeps telling me it's the starter. I've replaced starter and still have the same problem. I have had all the wiring and new key swith put in and still have the same problem. I guess were in the same boat!!!
Jul 09, 2008 | 1994 Nissan Pathfinder
Garden Logo
56 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
