Question about Holmes Products Humidifiers
Blinking red light - Holmes Products Humidifiers
Furnace blinking red light
makes squeeling only when furnace starts to turn self on
Dec 17, 2013 | Safety First Humidifiers
Both hi and lo light flashing, unit will not go on (used twice)
I have 3 exact units of the SWM5750DN-WM also and after cleaning them and put away for the summer (used in Winter 2016), and taking them out now (Oct 2017) for use, and all 3 are blinking green lights! The manual doesn't even list the blinking lights as a troubleshooting info... This sounds like a common occurrence so you'd think Sunbeam should have that readily available!
Anybody have a solution? I can't believe they are this fragile??
Feb 20, 2013 | Sunbeam Warm Mist Humidifier, SWM5750DN-WM
Humidifier filled with water, but red light is on
If you overfill it, the red light goes on. just dump a little out and it should go green. Worked with my crane duck humidifier. Hope it helps
Feb 01, 2010 | Crane Humidifiers
Humidifier control: red light is on. getting 24
the red light is lit because either you didnt install the manual mode resistor or your not using a out door thermostat but you have to hook somthing to the two terminals just to the right of the HH terminals
Dec 23, 2009 | Aprilaire 600 Humidifier
The red ligt on with water inside
FROM TROUBLESHOOTING SECTION OF MANUAL:
Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float
Jan 23, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Need help humidifier doesn't stay on
I've had this problem before and with mine, the issue is the water is not making its way into the correct reservoir on the bottom of the machine. With experimentation, I discovered that my tilting the machine slightly upwards on the righthand side corrects the problem (i.e. put something aprox. 3-5mm thick underneath the right side of the machine). You will hear that the water "move" to the left side of the machine and thus ensuring proper operations. I think this is a design flaw (for some machines) as clearly I have the same problem too.
Pc
Dec 19, 2007 | Bionaire Cool Mist BCM4530 Humidifier
Constant Red Light on Control Panel Circuit Board
The red light under the cover of the humidistat is fault light. This light typically indicates that there is an issue with your connection at the two wiring terminals labeled ODT on the humidistat. I would recommend checking to confirm that there is something currently connected to the two terminals. As a side note these two terminals can not be jumped out with a jumper, and must utilize either the outdoor temperature sensor (part 8052) or the manual mode resistor (part 4336).
Dec 08, 2007 | Aprilaire 400 Humidifier
Air-O-Swiss 7133 Humidifier
After you've cleaned it you can reset it by holding down the ON/OFF button for a few seconds.
Oct 25, 2006 | Air-O-Swiss 7133 Humidifier
Humidifiers Logo
100 people viewed this question
Top Holmes Products Humidifiers Experts
cwradio73
ray gallant
Ben Eng
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
