Question about Nordic Track NordicTrack T5 zi Treadmill
No matter what button I push it beeps3 or four ties.
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
Replace the old batteries ( if your system use batteries, and clean and tight the springs contacts from oxide, dirty, corrosion, use contacts cleaner) .
2) tight and clean the ribbon cables inside from display board, tight and clean the upper and lower connector.
3) adjust the REED switch, tight and clean the connector, and test with multimer for open or faulty see the diagram attached.
God bless youNo matter what button I push it beeps3 or four - accef3c0-2ec4-4b29-b2de-21426c2212e7.gif
Posted on Oct 21, 2013
Shifter locked cannot shift out of drive?
yeah man this is no big deal mine did that the day i bought it if u look up under ur car right by the driver side and have somebody push or wiggle the button u will c the cable that has come off ur transmission lever which is on the side of ur trany its made of plastic and is a stupid design u can either rig something up to make it stay or have the whole cable replaced cant by just the end like some cables i ended up puting it on with zip ties for a min then bought a little baby c-clamp and that has worked great good luck u can reach down there and put it on enough to get u going or at leat put it in drive to get u home
Jul 30, 2014 | 2003 GMC Envoy
How to get my 1994 chevy silverado 4x4 in to low range goes into four high just fine
Trading a 90 Silverado 2500 for a 94 240SX is a matter of likes. Chevy has a private party value of about $2515. Personally, no.--------------------------------------------------------------------------------
Renault CAN Clip
Apr 08, 2013 | Cars & Trucks
Stanton st150 spindle
Yes that's normal since the spindle leans of a thin metal plate , which you simetimes had to lubricate. Check if one ain't pushed don a bit (remove backplate of motor cap in the unit, four screws and lubricate it with thinker paste, since it has no storage zone, the same fault that technics has. And hit the plate it the middle, if it ain't flat anymore( not to hard to begin with and stop when it's flat. Push against the spindel and check that everything moves free.then check the tiny imbuss that keep the inning wheel at its's place , if you had easy movement, then it was loose , soo screw it a bit loose , hold the spindle from above and push it straight up and tied in thisosition. check if everything i s free again and close everything and screw it together, But a bit height differences doesn' t matter, why would it?as long everything runs free, they need to have space, so after these checks and lubriication which you have to do allways once a year at least and heavy stratcher more, but they din't use stantonJust relax
Nov 10, 2012 | Stanton ST-150 Turntable
I have a canon pixma mp450 printer that shows an error code of 6000 that will not clear itself no matter what I do. How do I fix this problem and what is it?
It may be
How To Reset Waste Ink Canon Pixma MP450
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 02, 2009 | Canon Pixma MP450 All-In-One InkJet...
My 97 z71 does not into or out of four wheel drive
there is a sensor on the tranny or transfer case that may have gone out check this and you may have a quick fix
Aug 23, 2009 | 1999 Chevrolet Silverado 1500
1999 Jimmy 4wd not engaging. It has push button
could be your front actuator or your actuator motor on the transfer case.
Apr 12, 2009 | 1999 GMC Jimmy
PUSH BUTTON FOUR WHEEL DRIVE FORD RANGER NOT WORKING
the transfer case is sticking from non use, change the lube in the case ( Ford ATF) and drive it for awhile it should be ok then.
Apr 07, 2009 | 1988 Ford Ranger
1993 4X4 BLASER 4WHEEL DRIVE
Your blazer is equipped with a shift on the fly four wheel drive. That means that at speeds less than fifteen miles per hour you can shift into or out of four wheel drive by simply pushing the four wheel high button. If you wish to shift into four wheel low. Stop, put the transmission into park or neutral, and push the four wheel low button. Same procedure for shifting back out. Never shift into or out of four wheel low while moving. And be careful in four wheel low. At full throttle your still barely moving, you don't want to blow your engine up!
Dec 31, 2008 | 1994 Chevrolet S-10 Blazer
Can not move transmission shift from P
try to keep it simple first and ck to make sure you have brake lites and the brake lite switch at the pedal is good. the brake lites have to complete a circuit in order to allow the shift interlock solenoid to operate shifter
Nov 22, 2008 | 1995 Chevrolet Corsica
Nordic Track NordicTrack T5 zi Treadmill Logo
114 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
