Question about Sharp Office Equipment & Supplies
HI THERE, how do i change sharp EL 509 WS DAL calculator to Radian mode. Thank you.
  • 207 Answers
SOURCE: I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 27, 2009
  • 1126 Answers
SOURCE: need a manual for the sharp EL-5103S calculator
http://www.sharpusa.com/products/support/view_all_models/0,2326,32,00.html
I don't see that model listed...are you positive on exact model number?
Posted on Sep 05, 2009
  • 8016 Answers
SOURCE: Sharp EL-520R manual?
Here is the link to all supported educational calculators. Download the one closet to your yours. I looked under commercial, and consumer and no 520 listed.
http://www.lifechangingbox.com/products/TypeManuals/0,1083,15,00.html
Hope it helps.
Posted on Sep 19, 2009
  • 8016 Answers
SOURCE: can you find shift button on sharp calculator (EL-531WH) D.A.L
On Sharp calculators, the shift key is the [2ndF] key.
Hope it helps.
  • 4 Answers
SOURCE: How do you turn the Scientific Mode on for a Sharp EL-512?
Posted on Oct 21, 2012
Testimonial: "Thank you so much! This was very helpful!"
How to darken sharp el-520w contrast?
If it can be done, you need to press SETUP then choose CTRST and use your left and right arrow keys to adjust the darkness of the digits on the screen. Unfortunately, some of the older models do not have this ability so if you do not find that that menu option it means that you cannot do it on the calculator.
Jun 25, 2014 | Sharp EL-520WBBK Dual-Powered 12 Digit...
HOw to change FSE code on Sharp Advanced D.A.L. EL-531X
To change the FSE code on your SHARP calculator press SETUP and choose 0. FIX means that it shows you all the decimal places. SCI is scientific notation, ENG changes the scientific notation in groups of 3's. NORM1 and NORM2 are your normal number ranges, however norm2 starts from zero and anything negative will be written in scientific notation.
Jun 02, 2014 | Sharp Office Equipment & Supplies
How do I get to degree mode instead of radian
Hit the DRG key to the right of the pi key. It should cycle from radians to gradians to degrees. A "D" should appear at the top of your screen rather than the current "R".
Good luck.
Paul
Apr 01, 2014 | Sharp el-531x scientific calculator
How do I get my SHARP EL-520W ADVANCED D.A.L. to display my answer in radical form?
Unfortunately, you don't. The EL-520W can show fractions, but not radicals.
Apr 05, 2012 | Sharp Office Equipment & Supplies
Manual for sharp advanced DAL EL 531X
HELP
i am 12 and my name is Geni. i bought this SHARPadvanced DAL green calculater for fractions and whole # with fractions but i cant fuger it out please help!!!!
Feb 15, 2012 | Sharp Office Equipment & Supplies
Where is the fraction button for sharp el-738 ? thank you
The EL-738 doesn't have a fraction mode like some other Sharp calculators.
Feb 02, 2011 | Sharp EL-738 Scientific Calculator
I have a SHARP EL-501W calculator and i am getting the wrong answers with the tan -1 function
The source of errors is most certainly due to the wrong schoice of angle unit (degree or radian). If the default angle unit set in your calculator is the degree, any value fed to the trigonometric functions (sin, cos, tan) is considered to be expressed in degrees. Consequently, if you calculate the arctangent ( tan^-1) of a value, the angle returend by that inverse trigonometric function is expressed implicitly in degrees.
Similarly if radian is the default angle unit in your calculator, any angle returned by an inverse trigonometric function (arcos, arcsin, arctan) is in radian.
Set the default angle unit as the one required by your problem at hand. This way, the angles returned will be in the right unit and you will not have a problem of interpretation.
Hope it helps.
Dec 07, 2009 | Sharp EL-501WBBL Calculator
Hope it helps.
Mar 26, 2009 | Sharp EL-531VB Calculator
Can you find shift button on sharp calculator (EL-531WH) D.A.L
Hope it helps.
Mar 23, 2009 | Sharp EL-531VB Calculator
EL-531WH, advance D.A.L
Press [ON/C] to restore the default floating point format.
Hope it helps.
Jan 27, 2009 | Sharp EL-531VB Calculator
29 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
