Whirlpool sm 8525492-b
Gets stuck on wash, the dial won't automatically advance to the spin cycle. This is on the normal wash section. Dirty gears, needs cleaning or lubrication?
  • 24 Answers
Sounds to me that the timer behind the dial is working improperly this is a cam operated timer and sounds like its malfunctioning. I cant look up the parts list off any site with the numbers u gave. but if I had to guess that cam timer is broke but a little troubleshooting would verify. remember if you decide to take a look inside the back panel yourself there are arc flash potential and electrocution. read manufacturer warnings and you may get lucky and remove the panel and find a schematic and troubleshooting guide. good luck.
Posted on Oct 21, 2013
jonniewalker
  • 1029 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
kakee
  • 1269 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
That's a timer problem. Check on the user's manual on how to reset the timer settings. The timer can be replace if found defective but you need a pro technician to do it.
Posted on Aug 29, 2008
applianceboy
  • 77 Answers
SOURCE: washing machine is not spinning, and getting stuck mid cycle
Check the maytag class action suit in reguards to the neptune issue. you may be entitled to an exseptional warranty call based on this reguards. there is a problem with both the wax motor and the control board.
Posted on Sep 25, 2007
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Posted on Aug 12, 2009
How do I remove the lid from a top-load wash machine in order to repair the lid switch?
Most have snaps holding the top down. Just, carefully, pry upward at the front of the lid edge.
May 02, 2015 | Whirlpool Washing Machines
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
My Whirlpool SM 8525492-A will not spin. Please Help!
I just ran into the same problem.....did you get a fix yet?
Dec 16, 2010 | Washing Machines
Have a 10 year old Whirlpool Ultimate Care II top loading clothes washing machine. In the "Delicate" cycle, it stops after agitating sometimes and will not kick into the spin empty part of the...
Yes it is a timer issue, and yes the whole timer will need to be replaced. If you are handy it is not very hard. You can order the timer from marcone.com with your model # and it will show you a parts breakdown so you can see hoe to replace it easier
Nov 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Whirlpool mo 110753790 It gets stuck in the wash cycle & will not move unless you move the dial. This happens while the heat light is on & light will not go off which causes the dial to be stuck....
Timer behind dial is defective if it will not advance on it's own. Either continue to advance past the defective section of replace it.
Jul 06, 2009 | Dishwashers
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
286 people viewed this question
Top Washing Machines Experts
