Question about Stormtek Gamer (SOP305DE2X) PC Desktop
How can I change operating systems
Ihave a dell computer that is running window Me and I wqant to change it to XP. It has enough memory and everything I just want to know how I can fully take off Me and then install XP
    Problem Solver:
  • 5 Answers
When you get the windows XP disk and insert into your computer restart your computer and a different screen will appear. I believe its going to ask if you want to boot from disk or hard drive, select boot from disk. If not, disregard last sentence and select from these options. It will ask about what to do with main drive C:/, you will have the options to Partition the drive reformat the drive or do nothing.
If you partition the drive it will save everything from windows ME and basicly cut, or partition, your drive in half and the second half will have XP on it. Only choose this option if you have enough hard drive space, if you have nothing on the hard drive that you would like to keep from Windows ME don't select this option. Aditionaly if you do select this option you will choose on boot up to startup with windows ME or XP.
If you reformat the drive it will dump everything from the hard drive and you will have a clean slate to put windows XP on. (probably your best option)
Do nothing will be the last option, of course it will do nothing and you will not continue installing XP.
After choosing your hard drive option the rest of the install is automatic, be warned that the install can and probably will take close to an hour.
Posted on Jul 07, 2009
    Problem Solver:
  • 5 Answers
Buy the XP UPGRADE. It is around $90 and you can find it just about anywhere thjat sells software. You need at least 512 of memory for it to run smoothly. Once you install the upgrade ME will be gone.
Posted on Sep 27, 2007
SOURCE:
Not enough virtual memory
Step 1:
Virtual memory is a portion of your hard drive that Windows sets aside to utilize as memory. When your RAM is over utilized, the operating system can swap pages of data to the hard drive to make more room. Swapping files, or paging, is slow, but it allows your computer to remain functional when your memory space is full. If your virtual memory space, or page file, fills up as well, you'll get an error. Fixing this issue is quick and the process is identical in safe mode or in a typical boot situation.
Change Virtual Memory Settings in Windows XP Click "Start" from the Windows desktop. Right-click "My Computer" and click "Properties." Select the "Advanced" tab and under Performance click "Settings." Select the "Advanced" tab and click "Change" under Virtual Memory. Click "System managed " to allow Windows to automatically adjust your Virtual Memory as needed. Click "Custom " to alter the memory space to your own specifications. Enter a value in MB equal to at least 1.5 times the of your computer's memory for the initial . Enter a value in MB no larger than four times your memory for maximum . Click "OK" and restart your computer for the changes to take effect.
Feb 13, 2013 | Microsoft Windows XP Professional
Ihave a dell dimension 2400 It is windows xp home edition.What cd would I order to restore it back to factory setting. I would appricatae it thank you Karen
Hi. I have a dell optiplex gx240, and I has to do this exact same thing to it.
You can download an iso image from the microsoft windows xp website, it is service pack3. Then just burn the image to a cd, and then take out the cd and put it back in.
It should autolaunch on it's own when you puit it back in.
When it gives you your choices, select repair install, if it offers, otherwise just let it run as normal.
You won't lose any programs, because you are just replacing the operating system to fresh, not the files as well. All your programs should still be there, all the short-cuts, everything.
Then once it's done, eject the disk, and revoot.
Your computer should be good as new, and maybe even a little faster!
Jan 29, 2011 | Dell Microsoft Windows XP Home Edition
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
Oct 15, 2010 | Dell Dimension 4700 PC Desktop
Error message Low on virtual memory
Virtual Memory is used by the operating system as an extension to the Random Access Memory (RAM). When the RAM does not have enough space to accommodate the entire running program, the inactive parts of that program are temporarily shifted to the Virtual Memory. These parts are then swapped back into the RAM as and when needed. If the Virtual Memory set on your system is not enough for the computer operations to run smoothly, then you will get the "Virtual Memory Is Too Low" error message.If operating system is xp then this problem can be easily overcome by increasing the Virtual Memory size.This is how you can do it by following instrutions:
  1. Click on "Start" and then click on "Control Panel.
  2. Double-click on the "System" icon in the Control Panel.
  3. Click on the "Advanced" tab in the System Properties dialog box.
  4. Click on the "Settings" button below Performance.
  5. Click on the "Advanced" tab in the Performance Options dialog box.
  6. Click on the "Change" button below Virtual memory.
  7. Click on a drive_letter below "Drive [Volume Label]" in the Virtual Memory dialog box.
  8. Click on the "Custom size" option.
  9. Click in the "Initial size (MB)" text box and type a larger value (for example, 600).
  10. Click in the "Maximum size (MB)" text box, and type a larger value (for example, 1500).
  11. Click on the "Set" button. Similarly change the Virtual Memory on other drives.
  12. Click on "OK" and then restart your computer.
Apr 07, 2010 | Microsoft Windows XP Professional SP2
I would like to buy a new dell but not sure how much memory i would need. I don't recall how much memory is in my previous dell. It is a dell dimension xp. Would you please let me know how many GB there...
With any new computer you should get 4 GB of memory, the more the better. There are two version of Windows you can get 32 or 64 bit. The 32 bit version of Windows has a 4 GB maximum on the memory, the 64 bit versions go much higher depending on the version you get. 4 GB will give most people more than enough to do what they need. To see how much memory you currently have just Right-Click on the My Computer icon and select properties. In the window that comes up you will see the memory you currently have.
Jan 30, 2010 | Dell Dimension 3000 PC Desktop
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Unable to download games on my computer and if it is a driver issue unable to find a free driver for it
Hi
i think
Game is to heavy for your computer to run
Might need more free memory or your sound & Graphic card are not supporting this game. Before you download any aplication from any website make sure your computer meets the reguirements, Such as Operating system, sound and Graphic card and make sure you have enough Ram space to run the software.
Apr 19, 2009 | Dell Microsoft Windows XP Home Edition
I have a Dell Inspiron Laptop Having Issues
You need to not delete the partion but you need to do a format on your HD (harddrive) to basically remove EVERYTHING. What you did was just installed a second windows onto your computer.
Feb 04, 2009 | Dell Inspiron 8200 Notebook
Slow computer
Pro won't make it run faster. Make sure the processor is fast enough to handle XP. If it's an older computer you've upgraded to XP, it may not have the horsepower.
Read this page from Microsoft:
http://support.microsoft.com/kb/314865
If the CPU conforms, the best thing to do is add RAM. I recommend a minimum of 1 GB for XP machines.
Make sure the hard drive is not nearly full, as that will limit the paging file that Windows uses. If your drive is near capacity (+90% full) it will slow down any computer, regardless of how much memory you have, or what speed the CPU is.
Jul 17, 2008 | Computers & Internet
Inspiron 1150 Slow startup, slow printing, unable to run 2 programs at once
What Operating System do you run? If it is Windows XP SP2 (Home Edition or professional), here are some things you can do to speed up your system. 1st you should remove all programs that are not required from the start menu. Start > Run > Msconfig > startup tab. Unselect all that are not necessary. Also Right click on my computer > properties > Advanced > Performance settings > Adjust for best performance. This should speed things up a little. I would recommend atleast 512 MB of memory to run Windows XP and its applications decently. You should consider an upgrade.
Dec 20, 2007 | Dell Inspiron 1150 Notebook
Stormtek Gamer (SOP305DE2X) PC Desktop Logo
238 people viewed this question
Top Stormtek Computers & Internet Experts
Ekse
Alun Cox
Are you a Stormtek Computer and Internet Expert? Answer questions, earn points and help others
