Palsonic tftv5545ledr TV
My tv has started to totally reset after about 5 minutes of use. After that about every 2 minutes. I have just replaced the main board in it, thinking it was a overheating issue. but it still seems to reset after 2-3 minutes
circuitworld
  • 335 Answers
SOURCE: LCD tv main/digital board
Send it to us and we will refurbish the board.....
e-mail me....circuitworld@comcast.net
Posted on Feb 11, 2009
SOURCE: Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
Posted on Sep 11, 2009
SOURCE: 3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Posted on Jan 21, 2010
SOURCE: TV Guide on LG TV
I have the lg du-42py10x tv with a cable card slot. I have Time Warner cable in Cincinnati Ohio. I split their cable coming in and put one end on the cable input and one end on the antenna input on the tv. I now have TVGOS with my cable card. By putting one end of the cable on the antenna RF input, I received the CBS station in analog. That is what you need to get TVGOS to work.
Posted on Oct 01, 2010
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
http://www.coppelltvrepair.com/search?Q=l42hdtv10a&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Posted on Apr 25, 2013
Code for a pdp4225hd
http://tv.manualsonline.com/manuals/mfg/palsonic/pdp4225hd.html
Free manual - see if contact information is available for the manufacturer of the
Palsonic PDP4225HD Flat Panel Television
Apr 22, 2018 | Televison & Video
I have a palsonic model no: TFTV492LED and I can't change it off AV1. I want to put it on HDMI I have no remote either.
Try the front panel button labeled Source; it's the second button from the left. (The first button is the Power button.) All of the buttons are on the right hand side of the bottom frame of the TV. Use the Channel Up/Down arrows to navigate through the list of inputs. Try waiting for the selection to take effect. (The documentation says press OK or the Volume Up button. Sometimes, the Source button on the TV functions as an OK button. This isn't clearly identified for the Palsonic.)
If the HDMI input is greyed out, the TV may not be seeing a compatible signal from the source. Try turning on the device when the TV is off, then turn on the TV. I'm not sure if this TV will correctly see the signal from a computer. However, on some laptops, you'll need to enable the external video first. This is disabled to save power. Then turn off the computer. Finally, turn on the TV before turning the computer back on.
Palsonic has the manual available for the TFTV492LED on the product (discontinued) site under the Downloads tab. See http://palsonic.com.au/archive/led-tv/tftv492led.htm . The direct link to the manual is http://palsonic.com.au/customer_service/led-instruct/Palsonic_TFTV492LED_Manual.pdf .
I hope this helps.
Feb 29, 2016 | Televison & Video
When I try to retune TV to pick up new TV stations I get sound OK but a black screen with message invalid format.
Check stations MPEG format . Check if it is MPEG4 and check if TV can decode MPEG4 . A firmware update may be available on tv and may fix it but it has the risk of turning the tv into a brick if something goes wrong during a firmware update.
suggest contacting palsonic to see if firmware possible and which one to use.
http://www.palsonic.com.au/customer_service/upgrade/default.htm
Feb 23, 2016 | Televison & Video
Need a remote for a PALSONIC 32'LCD TV Model no PLCD32HD Thanks
Universal remote control setup codes to Palsonic brand TVs are 028,019,092,082,045. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 07, 2013 | Televison & Video
I have a Palsonic tv and it keeps turning off ,what could be the problems
There might be some loose solder terminals at its main power regulator board.
Dec 01, 2012 | Televison & Video
My palsonic digital flat screen tv i have had for 2 years now works fine one day then a few days later it wont start for some reason and remains like this for hours if not days. so whats the problem it...
Most of these problems and causes for LCD and Plasma tvs are having a hard times turn it on one day work the next don't.The tv power supply board it is the causes and the problems 90-95% of the times.That the board where the tv a/c power cord plug into it.U must have all the tools.U have some basic skills of soldering and know basic electronic also.Take the tv aparts and check the tv power supply board carefully for dying components parts like capacitors parts,these dying capacitors are bulging up or puffing on to it tops and leaking to causes these delaying tv to power on or hours or days to get it on again.Replaced all these dying and bulges or puffing up onto it tops capacitors parts with the same Miro Farad and those voltages on the capacitors parts 5 or 10 voltages higher than those dying capacitors u are replacing.Than those capacitors will with stand heat better and last longer too.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 14, 2011 | Televison & Video
WHEN TV TURN OFF SCREEN LIGHT SHOWS SKY CLOUDS BACK GROUND COLOR WHY
Hi, Your tv is start to spoiled. But it is quite normal if your tv is back to normal after about 5 minutes. If after 5 minutes the screen stranger background still persist, unplug your power chord. This will totally cut the power supply for your tv.
Jan 20, 2011 | Hitachi 60V500 60" Rear Projection...
Codes for palsonic televisions
Hi, that TV is not listed in the code list for your model.. You can try an automatic search by doing the following:
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode
3. Press and release power. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
For future needs, here is the link to your manual:
Bookstone 538744 remote manual
Apr 12, 2008 | Brookstone 538744 Remote Control
Total control remote
http://www.crestonline.biz/files/support/remote_controls-Total_Control/URC_4110_B01--Manual.pdf
this is the instruction manual for the TOTAL control remote and the 5 digit codes for all TVs it is a pdf file and can be printed 16 pages, My Mother-in -law lost control of her TV when we replaced the batteries and after searching the net found the manual while searching for the TV code Palsonic, numeroous attempts failed searching for the remote details, but there it is.
Mar 14, 2008 | Televison & Video
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
