Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
I used pure gas instead of added oil to the gas on the blower now the pulley has not pull to it...and it won't start
    New Friend:
  • 3 Answers
You ran it with straight gas. For how long? Did you turn it off or did it shut down.
The oil mixed in the fuel is to provide lubrication to the moving parts to prevent metal on metal wear and excessive heat.
If the engine stopped itself, it most likely has been damaged. If you noticed it quickly, you may still be able to use it. Will the recoil pull and attempt to start or is it seized?
If it won't attempt to pull, then I suspect the engine has suffered access wear including scoring of the cylinder wall, piston and piston rings. A rebuild is necessary and may not be worth it vs. cost of replacement.
Posted on Oct 22, 2013
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Won start
Depending on set up there's a chance because you ran it out of gas the bowl is dry? Get some old school lighter fluid pull out the plug squirt some into hole , doesn't take much. Reinstall plug quickly and give it a pull and see what happens
May 08, 2017 | Briggs Stratton 020273 Elite Series...
Leaf blower not pulling fuel into carbeurator
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to replace carburetor.
Dec 31, 2011 | Craftsman Garden
My craftsman 32cc leaf blower won't stay running
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Nov 06, 2011 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
My redmax eb7001 emits white smoke while running, the more power...the more smoke
Your fuel-oil mixture has too much oil in it. The standard ratio is 40:1 which means one of the little bottles of 2-stroke oil (about 2.6 fluid ounces) is added to 1 gallon of gas. Homelite recommends a 50:1 ratio but 40:1 is better, at least in my opinion.
The last time you made the mix, did you pour the oil into the gas or did you pour the oil into a little bit of gas in the gas can, shake well and then fill it with a gallon of gas? The former can give you lots of smoke as well because it is not mixed thoroughly. The latter is the best way to mix because the agitation and the flow of gas mixes the oil better.
Other possible causes to this problem are: how old is the mix you are using? Did this mix sit all winter last and you sre using it now? If so, did you add some Stabil to the mix before storing?
Depending on your answers to the above questions, you can determine why you are getting so much white smoke.
My recommendation to you is to:
(a) Empty the blower gas tank.
(b) Mix a fresh batch of oil and gas in an approved fuel container.
(c) Pull the spark plug and inspect it, if it is black/sooty replace it.
(d) Pour the new mix into the tank and start the blower.
This should get rid of the excess smoke, if it doesn't, let me know here. Good Luck!
Oct 22, 2009 | Homelite 'Yard Broom' Leaf Blower
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I just foun out that i forgot to add oil to gas mixture to my blo
hello, what you should do is drain out the gas from the tank into a clean container so you can add the oil to it and you should also check your spark plug make sure it's o.k. after draining out the gas try starting the blower a few times with out the spark plug wire connected to the spark plug this will flush out and of the pure gas from the fuel lines, after doing this re-connect the Spark plug wire and add your fuel/oil mixture and re-start, it might take a few times for it to start due to all the gas in the engine but it'll start also if your blower has a primer bulb you may want to prime it a few times after adding the fuel oil mixture to get it in the combustion chamber, if after doing this you still get nothing you'll want to re-place your spark plug it might be fouled out. good luck
Mar 25, 2009 | Craftsman 4 Cycle Blower/Vac
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
202 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
