Question about Fossil Sport Collection watch #AM4168 Watch for Women
I have a ladies Fossil watch #AM4168. The battery went bad on it and when I changed it out with a brand new battery and the second hand won't move. I took the battery out thinking I was sold a bad battery and they tested it at the store and it was fully charged and good. I put it back in and the watch still won't run. What am I doing wrong?
  • Barbara Keykens
    Barbara Keykens Oct 21, 2013
    "I would agree with you if it were not for the fact that when I first put the battery in it works for 2 seconds. A voltage tester shows that the battery goes to good and then drops down right away. Is it possible that the watch is shorting out somehow between the positive and negative?"
  • 2,113 Answers
It is a common logic problem. The watch stopped working. You assumed it was the battery; hence your assumption was wrong. Therefore the obvious answer is that the watch broke and that a battery would not help unbreak it.
Posted on Oct 21, 2013
Testimonial: "I would agree with you if it were not for the fact that when I first put the battery in it works for 2 seconds. A voltage tester shows that the battery goes to good and then drops down right away. Is it possible that the watch is shorting out somehow between the positive and negative?"
5 Suggested Answers
SOURCE: how to open the back of a Fossil pocket watch?
battery change
Posted on May 18, 2008
escapement
  • 2334 Answers
SOURCE: Brand new watch won't work
Check your users manual if your watch have two batteries. If yes, you need to replace digital part battery.
If your watch has only one battery, your digital screen or plate is defective. Bring it back to the retailer and ask to replace for the decently working watch.
But first of all try to fiddle with all pushbattons- sometimes it helps.
Posted on Dec 20, 2008
escapement
  • 2334 Answers
SOURCE: Cannot get the cover back on Fossil watch after changing battery
First open your bracelet. Then align groove in caseback with crown and press that side lightly into the case. Then using both hands(one from dial side, another from back) press as strong as you can.
If this do not work:
Get mens leather belt and place it on flat surface(table top). Lay the watch face down on that belt. Again adjust caseback as before and using your weight push caseback down with both hands.
NEVER use hammer or similar.
If none of these works- go and see your nearest watchmaker.
Posted on Dec 21, 2008
escapement
  • 2334 Answers
SOURCE: remove the winding stem/crown.
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
Do not forget to rate, please.
Posted on Jan 09, 2009
Hands on watch do not move but the seconds digital part still works. It is a fossil watch JR 8623.
your watch has two batteries you have to change the small one that power up the hands. the size of that battery is sr621. i hope i had been helped you.
Sep 05, 2011 | Fossil BIGTIC ANIMATION DISPLAY SILVER...
I have a big tic fossil watch. The flashing second is working properly, but the hand doesnt. It looks like slowing down. How can I fix this problem. Thank you
your watch has two batteries inside, the small battery is the one that had to be replaced. it is under the big battery, the small battery makes the minute and hour hand move while the big battery makes the seconds flashing. i hope that i had been helped you.
Aug 01, 2011 | Fossil Big Tic JR7896 Watch
Brand New Watch second hand won't move. won't keep time.
The watch has a problem in the timing module and the second hand won't move (a cog wheel issue) this is clearly a manufacture defect that can not be remedied and should be returned since it is under warranty.
Feb 27, 2011 | Fossil Watch Style # ES2074
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Nov 05, 2010 | TechnoMarine Cruise Watch
I changed the battery in my Fossil ladies watch and it still will not keep time. The hands are going around but it is not keeeping up with the time
mcdevito75 here, Look for a small watcg repir shop in your area. It could be the mechanism is going bad. If you changed the battery for this problem and you have the same problem, then the quartz is ging bad, (the mechanism)
Jun 17, 2010 | Fossil JR8096 Wrist Watch
mcdevito75 here, Just had the battery changed, if the watch was running fine before the last battery died, and now with this battery change the watch can"t keep time, try another battery as any Battery can be weak just from storage.
Jun 14, 2010 | Fossil JR8096 Wrist Watch
Second hand doesnt move. The ''stop watch'' second hand moves instead of the ''main'' second hand. also the stopwatch feature doesn't work. My watch is a Fossil Blue Titanium model TI-5071
Sounds like a job for Fossil!
Go to their web site "www.fossil.com" and at the bottom of their page is a menu which includes "store locator".
Feb 24, 2010 | Watches
Not sure what parts should be moving on new Fossil Me1020 watch.
I have a Fossil Twist ME1011, basically the same idea behind the one you have. What happens is there is a weighted third-circle that is in the back of the watch behind the battery (you can't see it) that spins a spring (the spring is the bottom seethrough part that ISN"T moving!) the spring then moved the UPPER seethrough part, which in turn spins the second hand!
IF the second hand stops working, carefully take the back off the watch and you'll see the weighted third-circle that I was talking about. It should spin, and in the middle there is a tiny flat head screw. The screw can get loose, so gently tighten it and the second hand should work again!
May 30, 2009 | Fossil ME1020 watch
Hi, My ladies black and siver ladies bracelet watch is not keeping time. first the plate in the face kept moving position according to the movement of my wrist. Then it stopped keeping time, so I took it...
I would send it to Fossil anyways. You say the plate is moving, I'm thinking that's the dial (the thing with the Fossil logo and # on it) That is deffinantly under a warrenty. Fossil is pretty good with helping even if you don't have the paperwork, and don't live in the United States. Look them up on the internet, and if you can call first they will give you a # so when you send the watch they already know what to do and can start fixing your watch faster. Tell me what happens , or if I can assits you further. Good Luck!!!
Jul 08, 2008 | Fossil Watches
Fossil Sport Collection watch #AM4168 Watch for Women Logo
135 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
