Question about Garden
Simplicity Legacy mower 17hp
I have the model number and serial number and looking for the year of my lawn mower. Model 1694292 Serial 00905
    New Friend:
  • 16 Answers
You will have to get that from Simplicity, but having the model # does allow you to identify and buy parts. For example here:
http://www.superxpower.net/pages/OemParts?aribrand=AYP#%2fSimplicity%2f1691135_-_917H%2c_17HP_Hydro_and_48%22_Mower_Deck%2f48%22_Mower_-_Cover%2c_Drive_%26_Bail_Group%2f12063%2f18874
Posted on Oct 21, 2013
  • 5 Answers
SOURCE: I need a free manual for a Craftsman 15.5 CI,
Go to the sears web site, then go to parts section, then to owners manual section. Type in model and serial number. Then you can download the manual for free.
Posted on Apr 25, 2009
  • 201 Answers
SOURCE: I have a simplicity model 4211 lawn tractor with no spark.
terry, check for kill line on motor to see if grounded out,you can remove from ground clip.
also you say you checked points??????
check for flywheel to coil pickup clearance .
point type coil to flywheel the airgap should be 25- 1000ths with feeler guage. on electronic ignition coil to flywheel pickup the air gap should be set @ 10-1000ths with feeler guage. hope this solves your problem..........lemmee kno.....chris
Posted on Jun 07, 2009
  • 127 Answers
SOURCE: HOW DO I GET A MANUAL FOR LAWN MOWER AND ENGINE?
please double check model # and let me know
after the g sholud be a #then 11
13AN77KG_11
Posted on Jun 30, 2009
  • 12 Answers
SOURCE: my mower brakes do not work
The adjuster is on the right side just in front of the rear wheel. its the clutch rod / brake rod . you will see a spring on the shaft with two nuts one used to lock the adjustment. loosen the nuts and turn the nuts so the nuts go towards the back of the tractor. keep checking the peddle for brake .
Posted on Sep 19, 2009
rwvanlue
  • 486 Answers
SOURCE: what year is my simplicity lawn tractor model
You are missing one digit on the model number, but I believe it to be a Regent 16hp 2001-2002
Posted on Nov 22, 2009
What year is my simplicity 50 inch riding mower with bagger. Model # 1694624 Serial # 00641
hi byron.
i can not find your model number.but try this link and scroll down the page might help you out.
What year is my simplicity 50 inch riding mower with bagger Google Search
Nov 02, 2017 | Garden
MTD model number 13RL771H029. I purchased it in 2008 with 46" deck. Are all 3 spindles the same part number
I have an operator's manual for an MTD Model Series 760-770 Lawn Tractor. This Manual seems to indicate two different part numbers for the spindles on a 46" deck. One spindle is a Double Pulley, part number 618-04134B. The other two spindles are single pulley, part number 618-0240A.
However 760-770 is a series number. So this does not necessarily match your machine. The first question is what year is your Lawn Tractor? Following is a discussion of MTD serial numbers from 1997 till now. Pre 1997 is a different discussion.
The second question is what is your actual Model Number?
Locating Your Model and Serial Numbers
The model and serial numbers are essential to find correct MTD® genuine factory replacement part numbers for your outdoor power equipment. Once you know these numbers, you can use either the illustrated parts look-up tool or the operator's manual download to easily search for the correct part numbers needed.
What should my model and serial number look like?
MTD's current (1997 and later) model and serial numbers are generally 11 characters in length. A character could be a number, dash or a letter. If 0 represented all numbers and/or dashes and X represented all letters, the model and serial numbers should appear as follows: 00XX000X000.
These are made of both letters and numbers, and typically look like this: 11AA111A111.
Apr 11, 2015 | Garden
What year is simplicity model 1693920 serial no 06613
Need the code no, One after serial No. First no. is the year.
Dec 26, 2013 | Simplicity 38in Regent 21hp Briggs
Tractor serial numbers
ITS IN THE ENGINE CODE NO. LIKE 99820 MEANS 1999 AUGUST 20TH
Oct 21, 2013 | Garden
What type of engine is in the murray lawn mower model # 226110x92a ?
Murray is part of the B&S Power Products Group -- I think that happened in 2004 with the Simplicity purchase, so it's a safe bet that anything from that point on has a B&S engine.
According to the model number, it should be a 2003 model year, or somewhere thereabouts. Looking at my manual for that mower, they built them with a variety of engines, including the B&S Classic, Quantum, Sprint and Quattro models, as well as several Tecumseh models.
If you will post the full engine model and serial numbers, I can tell you what you've got. Note that some engines will have the numbers on a tag mounted to the enine, while others will have the number embossed or stampen on the engine - often on castings or sheet metal parts. Post all of the info on the engine tag or stamping.
Jul 18, 2012 | Garden
Can a serial number tell me what year a lawn mower is?
I think so try looking it up more there may be a place to type it in and it will give you info about it.
Feb 26, 2012 | Yard Machines Garden
I have a simplicity garden tractor with a 32 inch mower deck. i would like to restore and find out what year it is. the serial number is 010410. deluxe model number is 990287 and the standard model number...
http://www.simplicitymfg.com/manuals/index.cfm?rd=1
If you look at the manual you should be able to narrow down the year by the serial no.
Nov 01, 2009 | Garden
What year model is lawn tractor (mower), advice or solution
Hi there Avu
It's quite east to see when was your tractor was made, follow these simple steps and you'll know how to see what model it is
  1. Lift the tractor / mower seat (pull it up)
  2. You will see there's a small metal label with the serial and model number of the tractor / mower
  3. Check the serial number of the tractor / mower
  4. the first six digits of the number are you the model month day and year (i.e 090999XXXXXXX this tractor was made in September nine in 1999
Hope this helps
Attached is an image of the tractor seat and the metal plate
Sep 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman LT 1000 with Briggs and Stratton 20 OHV V-Twin Engine 42 inch cut model number 917271910 What year model tractor do I have?
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Aug 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
