Question about Samsung HF1000 Bluetooth Headset
Hf1000 pairs ok and the other person can hear me when i talk but I can't hear anything from them the volume is all the way up
Volume on ring and talk too low How can I boost the volume
perhaps getting him a hearing aid would be quicker way to fix problem . most phones have limited volume .
Feb 22, 2016 | Lands Phones
I could hear the person I call, but the person cannot hear me
Ensure you haven't muted your call. Press both volume buttons. If this doesn't work there may be a problem with your microphone. Also ensure your boom is fully extended.
Mark
Motorola Support
Jan 23, 2014 | Motorola Mobility H730 Bluetooth Headset
I have a samsung hf 1000 which speaks to me in chinese but i need it in english, any ideas please?
I did this to my HF1000 Handsfree device this evening as I had mine in chinese language as well today.
Power up the unit the vioce will say power on, wait for silence then push and hold the Call button, the unit will speak the pairing instructions including the pair code of 0000. regardless of the language the voice will repeat the number four times, so even thought you might not understand it, you will hear the number repeat....
After a brief silence period, press and hold the call button again, the next announcement is the language selection menu. After the announcement press the Volume + (plus) button to change the langauge, this announcement is quite long. Wait for each announcement (they are maybe two full sentences long).
Press the plus (+) Volume button to again to change to the next language, wait the appropriate length of time and press the plus Volume key again, for the next language....
Chinese language is directly after English, and so you need to go throught the key press sequence about I think five times. English, then Chinese, Italian, Spanish then German, is the sequence I believe.
Hope this helps!
Oct 08, 2011 | Samsung HF1000 Bluetooth Headset
I have Samsung HF1000 bluetooth headset and I just replaced my phone. Unfortunately I do not remember the password and therefore I am not able to pair my new phone.
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Mar 30, 2011 | Samsung HF1000 Bluetooth Headset
I can only hear the person I am talking to through headphones, I want to hear them on my speaker
To solve this problem ,do this; goto start menu >control panel>sound and audio devices
in volume tab under speaker settings , click on "advanced" in speakers tab speaker setup:select desktop stereo speakers
click performance tab Hardware acceleration =full sample rate conversation quality=best. click on apply,and ok
select audio tab in sound and audio output. click on volume ,unmute all . increase all volume to high. close it.
select voice tab in click on volume ,unmute all . increase all volume to high. close it.
click on apply and ok.
then open your audio manager .increase play back volume and unmute all .
important :select default device (sound play back) .to your audio manager's default device . after apply all settings .click ok and close it. in sound and audio output. tick on "use only default devices". . do it and solve it
Sep 08, 2010 | Skype IM
My H12 has no sound, it will answer but i cant hear anything. I've tried turning the volume up but its not working
In that case it could be as simple as needing a new little speaker. The one in there is probably high-quality, but you should be able to replace it with any little speaker-- say from a pair of headphones. I successfully repaired the same problem in my Jabra bluetooth using this method.
It could also be a radio problem, however. Bluetooth headsets allow you to talk at the same time as the other person, so they use two frequencies at once. It could be that there is something wrong with the transmitter, but I'm afraid repairing that is beyond my abilities.
Mar 20, 2010 | Motorola Mobility Motopure H12 Bluetooth...
I can hear but person can't hear me
While talking, turn up your volume on the headset. If this does not help return your bluetooth for defective voice pickup censer.
Dec 07, 2007 | Motorola Mobility H350 Wireless Headset
Call just drops. I can hear but person I am talking to can not.
Nov 29, 2007 | Motorola Mobility H350 Wireless Headset
My mobile sony ericsson k800i
i am having microphone problems. the person i am talking to cant hear anything as its volume is too less. when i record anything in sound recorder, the stuff is recorded but the volume is low that i cant hear anything during playback
Nov 16, 2007 | Sony Ericsson K800i Cellular Phone
I can hear people talk but they can't hear me.
Sounds like this could be a volume control that might be on your PC and not the headset. Be sure all your levels are set correctly and all the correct audio hardware settings are in. Reason I say this is some sound cards and maybe even the drivers themselves might receive and play at a different volume than the transmit side of your Skype connection. Not sure but check to be certain.
Oct 26, 2007 | Motorola Mobility H350 Wireless Headset
Samsung HF1000 Bluetooth Headset Logo
29 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
