Question about HP ProLiant ML350 G4p Server
Server won't boot after bios update
I have Proliant ML350 G4p server that has worked fine for years under Windows Server. Yesterday I upgrade the firmware, and after the restart procedure, the server won't boot.... The fan run like a 747 at the take off, all led are green but nothing show up. Any idea, how to fix that ? Thanks
  • 2,113 Answers
Http://forums.whirlpool.net.au/archive/1758237
Posted on Oct 21, 2013
  • 17 Answers
SOURCE: HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (&not use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
Posted on Jan 24, 2009
  • 48 Answers
SOURCE: HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Posted on Mar 20, 2009
  • 17 Answers
SOURCE: Connect HP Proliant ML350 Server.
Please verify if your server power specs support 110 or 220 V. If you are in the US, eventhough you might have connected a 220V cable the line voltage can be 110.
Check with your power company if they can provide you the necessary wattage of the server.(Specs are printed on the power supply. you can read it from HP web also)
Once you are sure that, connect both power suppllies and try booting.
If the error still occurs, it can be a power supply failure or some other hardware failure.
Regs,
Posted on Jul 10, 2009
ted1430
  • 339 Answers
SOURCE: hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
Posted on Jul 12, 2009
Mustgo
  • 2359 Answers
SOURCE: My HP ProLiant ML350 G5
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Posted on Jan 05, 2011
My server cant boot after a fresh intall
Reshuffling disks will disturb the Logical drive .Recreate RAID Install OS , Set the Boot controller order in system bios Pressing F10key
Jul 25, 2012 | HP Compaq ProLiant ML350 G3 Server
Boot controller 0 mb
reinsert RAID Controller CARD / Recreate RAID ,logical volume
Apr 27, 2012 | HP ProLiant ML350 G4p Server
Open Proliant ML350 G4 tower without the key
use minus screw driver. I opened it with the same :)
Jan 07, 2012 | HP ProLiant ML350 G4p Server
03 critical lock up detected code fc08h
Clear NVRAM & Update BIOS with latest version
Dec 12, 2011 | HP ProLiant ML350 G4p Server
How do you access the BIOS in a Proliant ML350 G3 server?
When you boot up your system, press F9 when prompt. It will apper usually at the top right of your monitor.
Good Luck.
C2Solutions
Nov 10, 2011 | HP Compaq ProLiant ML350 G3 Server
I have a proliant ml350 g3 rack mounted server that is in a constant reboot loop. It once gave a blue screen of death with the error message of NME Parity error, so I took out all but one RAM stick and...
Put RAM's in Identical form and check.
clear NVRAM and Check.
check the array controller
update BIOS and Array controller firmware ( disconnect HDD's from the cage before
updating the latest Firmware( download from hp.com/support and drivers )
May 27, 2011 | HP Compaq ProLiant ML350 G3 Server
No display from the server mother board, Model hp proliant ml 350 how to solved it. Biswajit
try different ram,if rams not the issue you can try reheating the graphics chip on board with the heat gun,find instructions on how to reheat the gfx card on youtube so u get some idea what to do
May 09, 2011 | HP ProLiant ML350 G4p Server
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
HP ProLiant ML350 G4p Server Logo
109 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
