Question about Proscan Televison & Video
Proscan PLED1960A-E 19" LED Flatscreen. The sound
Proscan PLED1960A-E 19" LED Flatscreen. The sound from the speakers is not good. I have HDMI cable feed from Direct TV to the Prtoscan TV Can I attach outboard speakers from audio out using normal L & R cables from the tv to the speakers and if so how do I mute the speakers in the tv Thanks for your reply John
SOURCE: No surround sound when watching TV
hdmi can only pass pcm 2.0 digital for the separate cables you may try to switch them to another output from the monitor to the receiver or if you can get your hands on a spd-if cable (one single fiberoptic cable that will go as high as 5.1 dolby surround)
Posted on Feb 01, 2008
  • 45 Answers
SOURCE: 42" pansonic plasma hdmi problem
if I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or Component.so you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Posted on Mar 25, 2008
shbuckler
  • 126 Answers
SOURCE: DVI-->HDMI cable causes tv speakers to hiss and pop
DVi to HDMI. ? hmmmmm
I recon you spend £49.99 and get a DVI & Audio to HDMI Converter. This will resolve the issue
Posted on Dec 25, 2008
skotkolr
  • 558 Answers
SOURCE: significant volume decrease when using Comcast cable box
you might have to talk to comcast about that most signals are low for reasons of conservation of bandwidth, they may also be sending 5.1 which tends to be lower volume and adds surround in.
mono is always loud, and that is what you get with 75 ohm coaxial cable (single screw in ).
hope this helps.
Posted on Apr 06, 2009
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Posted on Sep 24, 2009
Digital signal is blocked from TV
I really need a little more information to help with your problem. Do you have your TV connected to a satellite or cable receiver box via an HDMI cable or are you attempting to use the built-in digital tuner to receive HDMI over a HD antenna?
Aug 01, 2014 | RCA PLED2435A - Proscan 24 LED 1080p 60hz...
Connect Sound Bar to TV (flatscreen - Proscan)
How about fiber optic cable or composite cables. I usually recommemd that people do either of these.
Jun 04, 2014 | Proscan Televison & Video
Pc hdmi no sound
some televisions require a seperate audio feed from the HDMI cable to hook up audio. if you have the cables for this i would try that first. normally ends up having to go thru an AV connection
Jan 16, 2014 | Proscan Televison & Video
Proscan 42" LED 120hz TV no audio out except with hdmi
Look for the setup menu on the TV. It is common that you need to select either TV speakers or external speakers as only one will work at a time. If you want the sound to come out the audio output, you may need to select this option. Worth checking.
Dec 08, 2017 | Televison & Video
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
None of the connections for my ps3 will work with my 32lb30q proscan 32 inch lcd flatscreen?
The product description says that your TV has 2 HDMI inputs. All you need is an HDMI cable to hook it up.
OR
It also says that it has the A/V inputs (red/white/yellow). Which you just plug in the cord that came with the PS3, each plug with the corresponding color. Good luck and thank you!
Jan 13, 2009 | Video Game Consoles & Games
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
