Question about Craftsman Saws
The motor pully on my Craftsman 152.271250 came off. Very difficult to see let alone get to. How do I reattach it
2 Suggested Answers
  • 133 Answers
SOURCE: Need to replace drive belt.Never replaced. 42'
Take a look at how the belt is installed. Then you will have to remove the mower deck and belt from the pulley on the engine. There is probably something by the engine pulley that you will have to remove so the belt will come off. It might be a shoulder bold or a rod with a bolt holding it on. Same with the rear pulley. Then you just have to put the belt on one pulley and watch your fingers so you don't pinch them and turn the other pulley and the belt should go on. reinstall any bolts you removed and install the deck.
Posted on Oct 10, 2009
Craftsman M#917270810 riding mower starts and runs, but won't move in either direction, rolls freely.
Have you had either of the drive wheels off. If so you may be missing one of the axle keys.
Jun 03, 2015 | Garden
Deck belt route for a Model #91725160 Craftsman Sears 14/6 garden tractor
i figured it out the pully beside the motor has 2 pully's side by side that i was missing but now i need a 9503H spring that is not made,thank's for all reply's
Oct 04, 2012 | Craftsman Garden
Craftsman LT2000 Blade is staying engaged all the time, just did a blade mandrel replacement, where does the spring for the blade control reattach? What would make the blades be in motion all the time?...
sounds like you may not have the right mandrels making the belt to tight and it cant be left loose enough to allow the blades to quit turning.Otherwise you didnt put the belt back on correctly if it is around the tightener pully the wrong way that to will make the belt to tight
Apr 09, 2012 | Craftsman Garden
I need both pullys for the motor and the arbor. They are cast alu and need to be replaced.
call Sears,Have model and serial number ready,ask for parts and service,they sell any part for any craftsman power tool .
Jun 14, 2011 | Craftsman 10" Table Saw
I was engaging the blade on my 17 hp craftsman lawn tractor and the engine died. Now the engine won't turn over. ???
the motor wount turn over if in fact the belt is tight around the motor pully. remove the deck belt then also make sure there are no switches not working.
Nov 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you remove an engine from a Craftsman dyt 4000 lawn tractor?
remove the deck and drive belt, then the pully and the four mounting bolts. unplugg all the wires and lift the motor out.
rural king has briggs and straton motors at their stores for a cheaper price than on line. I got a 18.5 hp for $420.
Jun 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor won't start and mower very difficult to push
is there a puddle of oil under where it made the clunking sound, that would mean the engine is blown. another thing to check is to see if the motor bolts that hold down the motor came loose and is hanging down there by keeping the pullys from moving right..good luck
Apr 03, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Wont start or turn over
slip the belts off the main pully that comes out of the motor. try to start . if no start ck engine oil and manually turn the motor by the pully back and forth until it turns freely. or you can have your batttery checked and check all the elect connections.
Nov 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Saws Logo
56 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
