Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Door drops down suddenly when opened - Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
  • 2,113 Answers
Your spring is hooked onto a cable to help ease the door down. It must have come loose. You'll have to open the door panel and panel under the dishwasher... and possibly have to pull the whole thing out to find the problem... only then can you tell if something is bent or broke.
Posted on Oct 21, 2013
I have an 06 pt cruiser when I bought it couldn't open door from inside. Suddenly door opens from inside and window won't come down what's the problem
Tests/Procedures: 1. Check the power and ground at the master switch mount in the dash. Pin 12 is power at key on and pin 4 is the ground.
2. Next try driving the left front window by applying power to pins 13 and 14, switch polarity should drive the window up and down. If not, check for broken wires in the between "A" pillar and the door, then gain access to the window motor and try applying right at the motor.
Tests/Procedures: 1. Check the outside door handle switch. It should ground the Orange/Yellow wire when the handle is raised. Tech Tips: The power window should drop slightly whenever the door is opened. The ensures a tighter seal to the convertible top.
May 04, 2015 | 2006 Chrysler PT Cruiser
Door doesn't open slowly, it drops down suddenly when opened. What is the problem please?
Pull the dishwasher out. You may see the mechanism and possibly broken spring or other part. (possible it's just come apart. You may need to remove side panels to see this mechanism for the door (counter balance) .
Apr 11, 2015 | Dishwashers
My lg dishwashers door will drop open suddenly
If it is sudden opening during cycle then it is due to pressure build up inside the dishwasher is forcing the door to open.
a) Most likely your door latch is not holding proper enough. Quite common on LG.
b) May be your vent in the dishwasher is blocked so the pressure inside cannot get out. If vent blocked you have plate drying problems too.
c) Is the dishwasher leveled properly. Is it leaning to the front. This will be that extra help for the door to open when pressure build up inside the dishwasher.
Sep 26, 2014 | LG LDF6810 Built-in Dishwasher
How do I adjust the door opening on my integrated dishwasher ?
The door springs are too tight. Please provide model number so that I can find the instructions to adjust the door springs.
Jul 30, 2014 | Tecnik Dishwashers
We have a built in diswasher MDBH969 AWQ which is less than 2 years old. Suddenly the Door to the washer drops down quickly rather than what appeard to be spring loaded and would drop slowly before.
Bbeldenjr, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Bbeldenjr), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool MDBH969AWS Builtin Dishwasher
Door falls open
The cables that are connected to the springs are broke, atleast one anyway. You'll need your model number off the machine to get them from a parts dealer. once you have them, pull the machine out a little ways and they install on the left and right side lower area.
May 28, 2012 | KitchenAid Dishwashers
Garage door repeatedly drops after opening.
Remove the cover from the motor unit and check the drive gear.
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Mar 15, 2009 | Refrigerators
Washer time-down problem
Check to see if your machine is connected to cold water, it should be. The problem could be the electronic thinks the machine is always connected to cold water at about 20 degree c. if connected to hot, the time drop if the it would take to heat the water to the incomming temperture Good luck
Aug 14, 2007 | Miele Touchtronic W1213 Front Load Washer
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
103 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
