Question about QMark BRH482 Heavy Duty Portable Electric Garage Heater 16,380 BTU
I have a QMARK garage heater Model#MUH0321. It runs constantly and will not shut off, I have to shut the breaker off in my electric panel. I tried to trouble shoot by disconnecting one of the thermostat wires but it just keeps running. It has run great for years I don't know what happened. Please help, thank you.
  • Jesse Abbott
    Jesse Abbott Oct 23, 2013
    I dont what switch it would be there bout a dozen wires going to heating elements, a board, and several other things that I have no idea what they are.
    Sergeant:
  • 194 Answers
I suspect the switch in the heater is defective.
Posted on Oct 21, 2013
  • Jesse Abbott
    Jesse Abbott Oct 21, 2013
    I will check it out thank you.
3 Suggested Answers
appman67
  • 33 Answers
SOURCE: Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
Posted on May 03, 2009
frcs68
  • 1605 Answers
SOURCE: MUH108
4awg is about the size of battery jumper cable. or 240v multi-strend cable. and 48A is big. double 40A brakers.
the heater is 208v 3-phase 34,000BTU
it is call out to use the 240 comercial wiring.
Posted on Dec 02, 2008
The heater runs constantly, the thermostat seems to work, I check continuity through it, it opens and closes. What else could cause not to shut off?
QMark MUH (0521) Compact Heater Wont shut off ... - Fixya
www.fixya.com > ... > QMark > QMark MUH (0521) Compact Heater
QMark MUH (0521) Compact Heater, wont shut off related issues. Get free help, solutions & advice from top QMark experts.
QMark MUH (0521) Compact... Repair Questions - Fixya
www.fixya.com/support/p437492-qmark_muh_0521_compact_heater
Recent QMark MUH (0521) Compact Heater questions, problems & answers. ...thermostat on and contactor makes buzzing noise, fan dont run but its not seized it willfreewheel when you spin it ... How do I turn off my q mark wall heater there.
QMark MUH (0521) Compact Heater Shut - Questions - Fixya
Dec 01, 2015 | QMark MUH (0521) Compact Heater
My Qmark electic heater keep tripping the breaker
You will need to provide additional diagnostic information. Most likely the breaker is defective. Warning: potential for injury is HIGH working on power electrical! Do not attempt if you do not have experience and training. Proper personal protective equipment and methods should be used. The running amps needs to be measured when the heater is turned on. Find the rating on the breaker and calculate 80% of this rating. The heater current should be less than this value. If the breaker is tripping when less than 80% is measured it is most likely defective. Measure all power legs on the heater. Also check the nameplate info on the heater Volts, Amps. Compare these values to the actual.
Feb 06, 2015 | QMark MUH (0521) Compact Heater
How to turn QMark Heater off
Ok if the switch isnt working I would go to wour electrical panel box and turn it off at the breaker.Then the switch that isnt working can be replaced with a new one.
Nov 23, 2012 | Heating & Cooling
Qmark muh won't shut off
I believe these models have a thermal switch on or near the heating element that normally runs the fan until the element has cooled. Similar to your home furnace. If the fan never shuts off this switch is likely bad. IF it takes a long time to shut off then it may be out of calibration. In either case they are non repairable parts and have to be replaced. If the heater is in a high spot resulting in a high ambient temperature it may take a while for the fan to shut down.
Dec 20, 2011 | QMark MUH (0521) Compact Heater
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
QMark MUH-35 Heater (elec. garage heater) how to reset the Thermo. runs all the time,garage is warm.
If you cannot regulate the heater at all and the unit runs all the time no matter what you do, the thermostat or fan switch may be faulty and require replacement.
Here's a web site for this heater from which you may be able to obtain parts and/or further information:
http://www.heatersplus.com/muh-35.htm
Jan 04, 2010 | Kitchen Appliances - Others
I pulled the thermostat off the wall, and it is getting no power. All the breakers seem to be fine. Still nothing
go to common and hot, if you don't have 24 volts then check air handler for blown low voltage fuse or if all breakers are good the transformer is probably blown, or your drain pan may have water in it causing the float switch to shut the system down.
Oct 27, 2009 | QMark HBB754 Hydronic Baseboard Heater -...
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
May 03, 2009 | QMark FBE15002 electric baseboard heater...
Heating & Cooling Logo
115 people viewed this question
Top QMark Heating & Cooling Experts
paulcarew
appman67
appman67
john h
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
