Question about Frigidaire Refrigerators
My Frigidaire dishwasher is making a clicking type noise when washing. seems to be still operating correctly and draining correctly
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 93 Answers
Clicking noise could be a swing arm hitting the rack..I would check that first
Posted on Oct 21, 2013
3 Suggested Answers
SOURCE: Frigidaire FRS26R4A Vibrating Noise
Finally called a service technician. He said the compressor was bad and needs replacing. Fortunately, I'm in the 2nd - 5th year of my limited warranty so parts and labor are covered. He also said that the FRS26R4A is "junk" and it helps to support his family.
Posted on Jan 10, 2009
  • 62 Answers
SOURCE: GE refridge temp control makes clicking noise
probably a few loose ends causing the rattle sounds it does it for most fridges.
Posted on May 11, 2009
Frigidaire FFBD2403LW normal cycle hum
Hello ddux97 - Often this occurs because either not enough water is being pumped to the spray arm or in other words the full flow of water is not making it to the upper spray arm. Will the spray arm rotate freely? If it does not, then you might have to remove or replace the spray arm assemblies since it is possibly damaged. Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle. If issue persists, I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Jun 20, 2013 | Frigidaire Dishwashers
Makes noise during wash cicles and dishes are not cleaned
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Nov 24, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
Frigidaire dishwasher is not spraying water from bottom
From what you have described, sounds like the sprayer arms are possibly loose or being held into place and can't rotate, by dishware.
Aug 07, 2012 | Electrolux Frigidaire Professional Series...
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Water will not drain out
    Check the drain filter located at the bottom of the wash tub. Clean if clogged. The pump noise could be due to non availability of the washed water continuously due to clog.
    Clean the drain filter. Check the final drain output after the pump(hose) for free flow if you have connected it to a drain system.
    Aug 03, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
    Frigidaire dishwasher noticeably louder - circulation motor?
    Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
    Jul 06, 2010 | Frigidaire Dishwashers
    Noisy drain pump on FDB635RF?
    Two questions: 1) Are there filters that need to be cleaned on a routine basis with the FDB635RF? and 2) What causes the scum left behind on glasses and utensils? I use a rinse aid, but doesn't seem to be helping. This is a recent problem.
    Apr 22, 2010 | Frigidaire 24 in. FDB635RF Built-in...
    Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
    there is a #10 torx screw holding that cover down.do not drill it out. after you take it off you can tell if the chopper is broken.be careful for broken glass.
    Oct 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
    Abnormal noise and vibration
    pump is viabrating against body remove frond base and separate metals or slip a bit of foam between
    should fix problem
    oterwise there may be obstuction in drain pump
    Feb 23, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
    Refrigerators Logo
    46 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
