Question about Dryers
Whirlpool cabrio dryer error code F30 - Dryers
SOURCE: error code AF Whirlpool cabrio dryer
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
Posted on Jan 10, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Cabrio Dryer 3 months old
"AF" is a restricted air flow condition. You say you've only had your dryer for 3 months, but have you ever cleaned the ducting? You need to check the lint screen after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know.
Posted on Jan 27, 2008
  • 1314 Answers
SOURCE: Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Posted on Mar 30, 2008
SOURCE: Keep getting error message AF druing drying cycle and I've cleaned the lint trap.
check for clog or kink in dryer vent
Posted on Jun 10, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
What does code f24 mean on whirlpool cabrio dryer
Inlet Thermistor Open F-24 flashes if the inlet thermistor is open. This fault code will ONLY appear when in the diagnostic test mode. See TEST #4a.
http://dryernotheating.net/whirlpool-cabrio-dryer-error-codes/#F-24
Feb 14, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
What is error code F30?
From Fixya's Jeff Rockwell
Jeff Rockwell
  • 5911 Answers
"AF" is a restricted air flow condition. You say you've only had your dryer for 3 months, but have you ever cleaned the ducting? You need to check the lint screen> after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers> will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know
Sep 13, 2015 | Dryers
I am getting an error code of AF when my Whirlpool Cabrio wed7300xw0 dryer is in operation. How can I fix this problem?
This is fairly common most of the time the blower drive belt or pulley has fallen off. This video should get you headed in the right direction. Although the video below shows a maytag dryer it is the same cabrio style dryer you have.
Sep 08, 2015 | Whirlpool Dryers
What does F1 mean on a whirlpool cabrio dryer
You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
What is the LF Code my washer puts out
Hi Sherry,
The code definition for LF is a LONG Fill (F30). What does that mean is the next question? Here goes.
a. The fill hose may have a pinch or fold between the connections on the pressure in .
b. Are the hose screens plugged at the connections.
c. Is the water siphoning out of the drain hose ?
d. Is the water pressure at peak, check valve, filters before washer.
Now if your savvy hungry. Here is a learning curve link
Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis .
Okay. The next link is for the manual for your favorite machine. Manuals and Troubleshooting Whirlpool Whirlpool Cabrio Washer Fault Codes . I tried this and you need registration.
I decided to go one step further and track down a printable and savable resource for you. Yes, all, the fault codes and what they mean.
I did pretty good from memory but that link leads you to a printout you can keep right by your washer. Most of the occurrences are easy to fix without a technician. Hope this makes your day. Better. Fare. Well.
Jun 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washer no longer spins
Most likely control board. On a cabrio main power controls everything. If it agitate and drains and does not spin that's what it will be especially if there are no codes. Only other thing that could prevent spin, is a bad lid lock. But if there are no codes it a board.
Apr 05, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
F1 code on my Cabrio dryer
According to the manufacturer the "F1" error code means a primary control failure. The correction is to replace themachine control assembly. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 | Dryers
Dryers Logo
963 people viewed this question
Top Dryers Experts
