Question about GE Dryers
I have a GE profile dryer model# DPVH890Ejww upon starting it turns for about 2 seconds then stops turning.I was going to check the belt ,But couldn't even figure how to get the back off and I'm very mechanically inclined.Please some advice or a How to link would be appreciated.
  • GE Master
  • 2,536 Answers
Couldn't pull up the model number so if it's a newer model you have to take out the top panel screws in the back,then go to the front and pop off the timer knob and there's a screw there that lets you remove the front control panel and then you can get at the other screws that hold the top on,this isn't an easy dryer to work on,it has a funky belt system in it.if it's an older model open the door and look up at the top panel,you'll see two screws there,remove them and remove the top panel,then look down the sides and you'll see a screw on each side remove them and remove the front panel.hope this helps.i'm going by memory and unplug the dryer before you get into it.
Posted on Oct 21, 2013
yalmer
  • 549 Answers
SOURCE: How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Note:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Posted on Feb 05, 2008
  • 864 Answers
SOURCE: Reset GE Profile Harmony Dryer
Try here: http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
Posted on Sep 15, 2009
dmftrucker
  • 1922 Answers
SOURCE: GE Profile gas dryer detected in error.....
unplug the unit for a period of time(2 hrs.) to possibly clear memory, unless they are "Hard-Codes" and can't be erased w/o finding out the service code from g.e.
Posted on Sep 27, 2009
dmftrucker
  • 1922 Answers
SOURCE: I have a G.E profile dryer dpgt750 cant seem to
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Posted on Nov 19, 2009
Testimonial: "Thanks for info was able to solve my problem thanks, Marty "
  • 21 Answers
SOURCE: The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Posted on Feb 20, 2010
How to get error codes
With the dryer OFF Press the following sequence of buttons My Cycle - Delay Start-My Cycle - Delay Start . Menu will come up. Scroll down to Error codes and select. Scroll using arrows through error codes
Mar 26, 2014 | General Electric Profile DPVH890EJWW 7.5...
GE DPVH890EJWW Dryer shuts off randomly after heated.
210 to 300 is OK
there may be a accuracy issue .
measurement tool's.
check damp sensor or thermo risistor.
other then that you have a bad main board
Nov 14, 2013 | General Electric Profile DPVH890EJWW 7.5...
I have a GE Profile Prodigy eletric dryer that wont start. When I turn the switch it hums and stops when I let go of the switch, but won't start. Is that a switch problem or motor? How do I tell?
That sounds like to me the drum belt is broken..GE dryer use a belt switch that if the belt is broke will perform exactly as you describe ..as long as holding the start switch the motor will run and as soon as you release the start switch the motor will stop.
To check for a broken belt remove the top by removing the 2 phillips headed screws inside of the door at the top of it and pull off the top to see if the belt is in place and attached to the drum..if no belt seen when top off its broken and laying down in the base frame
GENE
Aug 28, 2011 | Dryers
I hit start, it makes a loud buzzing sound for 1 second and nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 26, 2010 | GE Profile DPSB620ECWW Electric Dryer
Turn start button. Dryer begins working; as soon as I release, the start lever it stops
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | GE Profile Prodigy DPSR513GA Dryer
When I try to turn my dryer on, it just clicks - nothing starts up. The light turns on for a second, while I'm engaging the "start" dial, so i know there's power, but after that, nothing.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 10, 2010 | GE Profile DPSB613G Gas Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
138 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
