Question about NTI Backup Now EZ
Trying to install NTI Backup Now EZ (Toshiba version) get an "Error reading setup initialization file."
3 Suggested Answers
shahidkap97
  • 392 Answers
SOURCE: my computer won't power on after using backup now ez
when it is not compatible with the configuration of the computer,how can windows 7 be installed! you can reinstall the OS but only try xp if it is not compatible!
Posted on Apr 08, 2012
clairexiang1
  • 59 Answers
SOURCE: Can't run NTI Backup software on Windows 7
Try AOMEI Data Backuper. It can work well on Windows 7
http://www.aomeitech.com/features/system-backup.html
Posted on Dec 24, 2012
Runtime error with EZ Backup restore
Did you try to reinstall the EZ software? perhaps you accidentally removed (a part of) a program.
Then try to restor the data again.
Jul 08, 2014 | NTI Backup Now EZ
Nti backup now error message during installation
Install the software before plugging the device in. You may have to uninstall first. Right - Click on the installation file and click ' Run as Administrator'
Dec 05, 2013 | Computers & Internet
Have you installed the proper USB 3.0 drivers.
If not install the USB 3.0 drivers that support your motherboard.
Dec 11, 2012 | NTI Backup Now EZ
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
My computer won't power on after using backup now ez
Apr 07, 2012 | NTI Backup Now EZ
I used a Toshiba 1/2 TB external drive with NTI Backup Now EZ software for some years and then the laptop crashed. After byuing a new one the happy moment when all could be restored never appeared. The...
Maybe the restore function only works with the original piece of equipment. Ouch.
You might want to contact the manufacturer of the software to see if they have a fix or solution. Good luck!
Apr 10, 2017 | NTI Backup Now EZ
I originally downloaded NTI Backup Now EZ software from the Toshiba website to use with an external Toshiba hard drive I purchased and have been running both "File and Folders Backup" and...
Hello bobdurack
I'm not shure this is the solution but it's a possibility : has the letter of your external Toshiba eventually changed ?
Regards ,
fanaudi .
Mar 28, 2011 | NTI Backup Now EZ Software
Hi I'll briefly describe my problem I've an external HDD (Toshiba) with NTI Backup Now EZ software installed on it, and I used it to back up my files the problem is that I can't restore my files now...
You might need to get an older version of NTI Backup Now. I had the same issue. I was using Backup Now 4 which saved everything as .nbf.files. I downloaded a trial version of Backup Now 5.5 and tried to restore the files only to find .nbf files are not compatible with version 5.5!
I sent a rather facetious e-mail to NTI moaning about this issue and they sent me a trial version of version 4. If I were you, I'd do the same. http://www.nticorp.com/en/us/product/backup_now5.asp
All my .nbf files are now restored.
Jan 08, 2011 | Newtech Tech InfoSystems NTI Backup Now EZ...
The drive database cdrw32.bdb cannot be found i tied to replace file still didnt work now also says nti has stopped working
The following is installation instructions for CD-Maker Professional. For Backup Now, the instructions are the same, however, you will install it in the NTI Backup Now directory, rather than the NTI CD-Maker directory.
To install, please copy the "cdrw32.bdb" file use Windows Explorer or My Computer to copy the database file into the main folder for CD-Maker 2000 Professional. If you installed our software in a different directory then you will need to copy the file into your alternate location.
Example where database file is located:
C:\Program Files\NewTech Infosystems\NTI CD-Maker 2000 Professional
You can also use the find feature in Windows to find the exact location of the database file. Click "Start", the "Search", then "for Files and Folder", then type in cdrw32.bdb and click "Search Now". After it finds the file then you can read under the "In Folder" heading for the correct path where the database file is located. Use Windows Explorer or My computer to copy the database file into this location.
NOTE:
(1) It works only on full retail versions of NTI software
(2) For CD-Maker, it works for Version 5.1.1 or later.
(3) For NTI Backup Now, it works for Version 2.2.33 or later.
(4) For supported DVD burner models, CD-Maker V5.1.XX and Backup NOW! (and DriveBackup!) V2.X will support only the CD burning function of these models, not DVD burning. DVD burning is supported starting from Version 6.0 of CD&DVD-Maker, and Version 3.0 of Backup NOW! and DriveBackup!, respectively.
Thanks for using Fixya
Sep 13, 2009 | NTI Computers & Internet
Computers & Internet Logo
27 people viewed this question
Top NTI Computers & Internet Experts
Tproverb
Level 1 Expert
Mari Criss
Mari Criss
Level 1 Expert
CruzSophia
CruzSophia
Level 1 Expert
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
