Question about Samsung "UN40D5500 40"" LED TV "
How can I off the 3d effect in my Samsung led UN40D5500
  • Samsung Master
  • 5,063 Answers
When I looked at the specifications for the UN40D5500, that TV doesn't have a 3D video option. It does allow for 3D audio on the digital audio signal. The UN40D5550 has 3D video. To toggle through the 3D settings, press Menu on the remote (in the center of the row above the arrow toggles) and use the down arrow to go to the Picture sub-menu. Press Enter then with the arrows go to 3D and press Enter. Under 3D Mode, you can toggle with the left and right arrows through Off, 3D, 2D upconverted to 3D, side by side images or two images stacked one over the other. Press Enter to save the setting. Press Menu several times to exit the menu system.
If you do have the UN40D5500 and are trying to disable the 3D audio, press Menu and go to the Audio sub-menu. Then look under the digital audio options (SPDIF).
For other manuals for Samsung devices, go to http://www.samsung.com/us/support/downloads .
I hope this helps.
Posted on Oct 21, 2013
Samsung plasma tv has vertical lines
The most cost effective thing to do is just replace the TV. The cost to repair will be close to the cost of a new LED flat screen, they are very cheap now.
Aug 21, 2016 | Samsung PN51F8500 51" Full HD 3D Smart...
Have samsung un55c9000zfxa led tv with horizontal lines across screen can it be fixed?
It's either the control board or the display itself.
You'll have to find a TV repair company. They won't be able to tell you for sure until they test it, and they may charge you to test it. The control board should be a cost effective fix, the display won't be.
Unless you're trained in Electronics, don't open up the unit and try to fix it yourself, there are hazardous voltages even when the TV is unplugged!
Jul 18, 2016 | Samsung Electronics UN55C9000 - 55in 9...
How do I connect to wifi?
Setup menu - WiFi - LAN - Network if this does not work try going to web browser to get an error message.
Samsung 3D LED Smart TV Setup menu WiFi LAN Network
Mar 14, 2016 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Samsung led tv won't power on - red power light is flashing
check the conections between psu and led bars,if the problem still,then the problem is in the led bar board.
Aug 22, 2014 | Samsung UN40D5500 40" 1080p LED TV - Ultra...
SamSung TV Manual
You can check the manual here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dcf7891b289297c49c9a8bca9143d8bd&modelid=23870046&q=Samsung+UN40D5500
Nov 13, 2011 | Samsung 40 UN40D5500 TV
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
The display does'nt show the 3d logo so is this a fault because i'm not getting any effects from the 3d glasses and they do work (glasses)
U also must have a LED 3D tv for the 3D DVD movie play on a Blu-ray player to play to get for the 3D movie effect.U now that wright?
Nov 24, 2010 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Samsung SP42W4HPX, black semi circle bottom of screen & 3D effect
sir/mam the problem of your t.v is weak picture tube,i have encountered for that kind of problem already.
Jul 31, 2009 | Televison & Video
Samsung "UN40D5500 40"" LED TV " Logo
105 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
