To much noise and take to long to cool donw - Heating & Cooling
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
Have an ac company come out and do a full maintenance on your your system, call around and get the best quote so you do not get ripped off, this sound like low freon levels and if it is ow on freon the compressor will have a higher pitch to the hum
Posted on Oct 22, 2013
I have a Kawasaki GPX 600R there's some noise coming from the cam chain. Someone told me that a few gentle bangs on the tensioner would fix it. Is this true or its better to change the tension
how many miles, if cam chain they are about 80 quid maybe less or more, and this needs to be donwe right mate, or bent valves, it could be tensioner if low miles, so a billet one on ebay. they bolt on at the rear of the engine, low down the barrels external. a billet tensioner is about 50 quid, I might know someone who can make one, he does my suzuki ones, where are you. us uk?
Oct 07, 2014 | Motorcycles
My laptop keeps shutting donw after a short period of time and the cpu area is hot during this time. any help
Clogged heatsink and fan / copper radiator. You need to remove the CPU cover (if possible) and hoover around the fan area to remove dust and debris. You mat have to take it apart to get to the cooling parts though. IF you chosoe to remove the heatsink to clean thoroughly, remember to apply some CPU grease between the cpu and heatsink.
Jan 12, 2011 | Toshiba Satellite P35-S605 Notebook
The fridge donw cold not much but the top ddn't cold what cold cause it pls.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 06, 2011 | GE Refrigerators
I have a whirring or griding in my drivetrain. I can coast donw a hill and let the engine idle and I still get the noise. It doesn't sound any different going around corners and gets louder as the speed...
this sounds like(no pun intended) you have a wheel hub bearing assembly failing. they will start a whirring or humming noise and then a growling or grinding noise the worse they get. from your description it is a rotational noise and gets louder and maybe a higher pitch as the vehicle speed increases. have this checked out right away so no further damage is done. they are not cheap assemblies as most GM and Saturn vehicles have the ABS sensor built into them(if your Vue has ABS).
Nov 06, 2009 | 2004 Saturn VUE
I have a 99 chevy suburban and everytime i brake and let it go i hear a bid noise in the middle of the truck somewhere in the axle. or diferential people told me that its the differential moving and only...
You might try blocking the wheels so it won't roll and then put the transmission in neutral with the engine OFF. crawl under and try to turn the driveshaft. It should move a very little bit and not make any noise to speak of. If the shaft moves very much or clunks when you turn it back and forth you will probably have to replace the differential or have it rebuilt.
Jul 06, 2009 | Chevrolet C1500 Cars & Trucks
Whirlpool has water drip inside fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 25, 2008 | Frigidaire GLRT212ID Top Freezer...
When i am working on my HP laptop Compaq 6515b, sometimes, it suddenly shuts donw,and the laptop itself is extremely hot. sometims, it took 5 mins to open a word file. Someone told me that maybe there...
Hi, the problem sounds to me like your CPU is overheating.
Have a look or have a technician look at the cooling fan and see if it is still working.
Most CPU's are set to shut down when over hot to prevent damage.
Regards mistyman
May 08, 2008 | Computers & Internet
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
