Wearing belts fast and when compressor goes into idle empties all the air out of the system
SOURCE: After removing and replacing a completely shredded
It sounds like you have a valve floating.
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
SOURCE: our company has ingersoll rand
make sure the cooler is clean..change the oil filter if hasn't been changed in a while..could be bad thermo valve..oil level?How many hours on machine?
SOURCE: where can i find motor fan part # 2mtr
89264527 Cooling Fan 250mm 54480355 Cooling Fan 300mm
