Question about Xerox Phaser 8560DN Laser Printer
Anyone know what this error is on a Phaser 8860?? 13,264,42:57563
    Novelist:
  • Xerox Expert
  • 297 Answers
Printhead Reservoir Thermal Fault.
13,264.42 indicates the heater is too hot.
Make sure the room temperature is within the printers operating range (not too hot in the room).
Check that the printer is plugged directly into a wall outlet that is properly grounded (3 prong plug, not 2 prong with an adapter)
Check the printhead connections and wiring. (Be sure to turn the printer off at least 30 minutes prior to touching the printhead area).
If all of these things are ok, then the printhead needs replaced.
Posted on Mar 16, 2014
2 Suggested Answers
darkpain
  • 316 Answers
SOURCE: xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
Posted on Feb 04, 2010
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
Phaser 8860 error code 08,030.46;21225
The Media Path Motor Stalled
Solutions ranked by relevance:
Make Sure There is no Paper Trapped in the Paper Path
Power the Printer OFF, Wait 30 Seconds and Then Power ON
Oct 01, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Jun 23, 2009 | Xerox Phaser 6250 Laser Printer
Phaser 8500 has error message 37,016.43:35730
the error 37,016.43 is related to the 50V power supply.You can download a service manual here.
The password to open the compressed file is: printer1.blogspot.com
Look at page 3-44 (page 110 in the pdf file) and you will find the steps to troubleshoot the error.
It also contains a parts list in case you have to replace the I/O board.
Fingers crossed and good luck!
Apr 01, 2009 | Xerox Phaser 8500/DN Printer
Change ink cartradge 11ER00670, same error after new cartradge.
SYSTEM NEED TO BE RESET, CARTRIDGE MAYBE DEFECTICE, THE SWITCH MAYBE A PROBLEM, GO ONE LINE AND SEE IF ANYONE ELSE SEEN THESE TYPES OF PROBLEMS, GO ONLINE AND TYPE:
XEROX PHASER 5500N LASER PRINTER CARTRIDGE ERROR 11ER00670
ENTER
IF THAT WAS THE ERROR NUMBER YOU HAD
OR
XEROX PHASER 5500N LAZER PRINTER CARTRIDGE ERRORS
ENTER
OR
XEROX FOREM GROUP
ENTER
OR
MANUFACTURE NAME,MAKE,MODEL, DRIVERS AND SERVICE MANUAL
ENTER
ROD
Feb 09, 2009 | Xerox Phaser 5500N Laser Printer
Xerox phaser 7700 error 11
man...
listen .. you is with error
go listen cradle of filth the heavy metal :)
good bye
see you later
Oct 16, 2008 | Office Equipment & Supplies
Xerox Phaser 8500N Printer Error
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 reports Internal Error
I would suspect the elecrtonich module has gone bad.
Without an error tht is my best guess.
Oct 23, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8560DN Laser Printer Logo
97 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
