Question about Dell Computers & Internet
Pinouts N1000P-00 N1000P-00
I need the pinouts for a nintendo wii headset (usb pinouts)
The USB interface is standardized. Knowing the pinouts isn't useful for creating your own headset, but here are the pinouts anyway:
http://pinouts.ru/Slots/usb_pinout.shtml
Feb 03, 2013 | Nintendo Wii Console
Connecting usb
Usually red white green and black unless the motherboard has a cable connect lead already
The USB Pinout:
Pin
Name
Cable color
Description
VCC
Red
+5 VDC
D-
White
Data -
D+
Green
Data +
GND
Black
Ground
http://pinouts.ru/SerialPortsCables/usb_cable_pinout.shtml
http://pinouts.ru/Slots/USB_pinout.shtml
http://pinouts.ru/connector/4_pin_USB_A__USB_B__mini-USB_jack_connector.shtml
hope some of these will help you
Feb 24, 2012 | Foxconn 6100K8MA-RS Motherboard
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Dec 28, 2010 | Computers & Internet
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
Dell xps 720 750w psu dead
You could try on ebay looking for one or maybe call dell hardware support and asked to be transfered to the spare parts department.
Dec 01, 2009 | Dell Computers & Internet
Alienware with a Newton 1000W power supply (N1000P-00)
Craig,
I think you will find that your instintcs are right, there could be some component getting hot in the psu & the thermal cut out is kicking in & shutting down the psu.
With a 1000w psu there is no way it should be doing that if the psu is in good order.
Unless you have the gear to test the components in the psu & of course you are qualified & competent enough as they are not safe to work on unless you know what your doing, on the other hand if you know how to check components down to that level get the meter out & check out diodes and may be well worth checking some of the capacitors for bulging, thats a sure sign they are on their way out & will eventualy go pop.
Nov 08, 2009 | Alienware PC Systems Alienware Area-51®...
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
http://www.interfacebus.com/Design_VGA_PinOuts.html
More monitor pinouts,
http://www.montest.com/technote.html
Apr 21, 2009 | KDS K717s 17" LCD Monitor
Computers & Internet Logo
144 people viewed this question
Alun Cox
