Question about Kenwood Car Audio & Video
HOW TO TURN ON POWER WITHOUT CONNECTING THE POWER CONTROL
    Master:
  • 482 Answers
You can over-ride the power control, but the amp would be on all the time, not good, you must connect the power control per instruction
Posted on Oct 21, 2013
Machine lead its own life. Without using or even connecting the food control, it runs at full speed by it own.
Well, the first problem sounds like the control foot is stuck, and I would bet it is preventing you from setting the machine for normal operation. You can replace it either through a local dealer or on eBay.
Jun 13, 2014 | Singer Quantum 9920 Computerized Sewing...
How can restart TL-WA5210G when lose ip and restart buttom
From what I understand, your device enables you to connection to an open network on a long range distance. Impressive. This device looks like is it most effective with no objects (buildings, trees,ETC..) in the way. I wouldn't try to reset the device. adjustments must be made. Consider the remote network you are connecting to. The owner of that network may turn off the wifi signal also control a limited amount of IP addresses it assigns (devices). Personally, I like having my own network without having to rely on someone
else's control of there network. The admin of that network could even restrict certain sites to be viewed or used.
Jan 13, 2014 | TP-LINK TPLink TLWA5210G 24GHz High Power...
I have a kenwood kdc-w7544u cd player and a mutant mtpk 300-a amplifier and i,m trying to connect it together in my vauvhall zafira. i have connected all the leads except one, the blue remote lead as...
The blue remote lead is the one that turns the amp on and off with the stereo. Without any power going to this the amp will not turn on. You have to either connect it to the remote lead coming out from the back of your CD player (should be a blue wire as well), or connect it to another power source that turns on and off when the car does (such as an ignition wire). Connecting it to the blue lead from the back of the radio is the preferable and much easier way to do it. Without connecting this remote turn on you will not be able to use the amplifier.
Mar 19, 2011 | Kenwood Car Audio & Video
Can i access av channel without remote control?
If your connecting the likes of a DVD player, Virgin, Sky etc to your Tv via a scart. Then these should turn your tv onto the required Av channel automatically as a scart send power to the Tv.
Just make sure that you have everything connected up first of all before you turn the power on. Then what I would suggest you do is turn the TV on first then turn the DVD, Cable, Sky on after the tv is already on this should then change to the AV your appliance is connected to.
Hope This helps you out. Please Leave a thumbs up if this clarify things for you.
Cheers Little Dish Fitter
Oct 06, 2009 | Televison & Video
Use nps-330ab for a normal power supply
You need to ground pin 14 momentarily to turn the power supply on. Pin 10 provides +12v, pin 12 provides -12v. Diagram here.
Apr 15, 2009 | Dell Power Supply 330 Watts nps-330cb...
I need to get my powwer supply to turn on without my motherboard.
well if u want see your fans working without connecting the power supply you can short the green wire (pin) with any ground (black) to see your fan work.....
use a pin or a piece of mettal to short green and black pins
Apr 07, 2009 | Computers & Internet
Fidge beeps and warning door open comes on, temp fluctuates
I had this exact same problem. I replaced the PCB on the freezer. Cost approximately $100.00. Problem solved. No flashing door light, no fluctuations in temperature. YAY.
Jan 26, 2009 | Refrigerators
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
Car Audio & Video Logo
24 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
