Question about Simplicity Denim Star SW210
The needle doesn't want to go up and down . It's hard to turn the wheel. It will move just not without a fight.
  • Simplicity Master
  • 7,365 Answers
There could be a broken part inside, the machine needs to be serviced to find out what happened
Posted on Oct 21, 2013
How do I Move the flywheel Elna 334
Usually you simply grasp the wheel and turn it. Most machines use the wheel to thread bobbins, and typically you pull the wheel out, directly outward away from the machine, slightly, to disengage the gears so the bobbin will wind without the needle going up/down. If it's pulled out, it will just spin when you try to turn it and the needle won't move.
If that's what's happening try pushing the wheel in, toward the machine. You can't push too hard, really, it will either pop in or not. If not, and if it won't move, it may be seized, which means one more of the gears inside have stuck together from overheating of lack of oil. If so, it's going to need a repair man.
Hope it's just disengaged.
Oct 09, 2014 | Sewing Machines
Hand wheel rotates but stop motion screw doesn't rotate and it is not moving the needle up or down
Robin. Take off the hand wheel. Look for the funny looking washer with ears. The center fingers should be angled outward when you fit it into place (counter intuitive, I know) Fit everything back together and try it again.
Oct 25, 2012 | Singer 20U73
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
I have a singer 6106 but no manual. When I press the foot the needle doesn't move although the outer wheel on the right hand side of the machine goes round. If I move the inner wheel on the right the...
go to http://www.singerco.com/accessories/instruction-manuals and type in your model number, then click "search" to locate the manual for this machine.
Sounds like the clutch is disengaged on your flywheel. Hold the outside of it and turn the inside bit away from you to reengage it.
May 28, 2011 | Sewing Machines
Model 1249380: the needle feel like it has a lot of tension on it and won't go up and down freely, the hand wheel on the side is very difficult to move
Sounds like you don't have the machine properly threaded.
Try removing the top thread to see if the machine moves freely with the hand wheel.
If it does, then put in the top thread, and adjust the tension to it's lowest setting. Go from there.
If the machine is hard to turn without a top thread, oil it to see it that frees it up.
If not, the machine will need to be serviced.
Dec 18, 2010 | Kenmore Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
The needle is stuck,not moving.its very hard and the motor makes a sound but needle does not move.
Refer to your manual and make sure the bobbin winding feature is disengaged.
Turn off the power and remove the needle and if there is fabric, remove it also.
Open the needle plate look for thread tangles.
After cleaning, turn the hand-wheel by hand to see if it moves the needle up and down.
If it does, press on the foot pedal to see if it is working.
Any of the above could be the problem.
Mar 01, 2010 | Kenmore Sewing Machines
Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Jan 17, 2009 | White Sewing 1766 Mechanical Sewing...
Simplicity Denim Star SW210 Logo
62 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
