Question about AOMNI Corporation Magnavox 15MF605T/17 15 in. LCD TV
Have the Magnavox HDTV TV Monitor 15MF170V/17 and it will not turn.The Monitor light is blinking and it is yellow/orange. Don't why it won't power on. Do you have any clue on what the problem could be?
2 Suggested Answers
  • 226 Answers
SOURCE: lost my ac/dc adapter
Go to the philips-magnavox-funai web site:
http://magnavox.fox-international.com/
Use the 800 number ... tom
Posted on Apr 16, 2010
I have a Magnavox 15' HDTV monitor and it won't turn on, when I push the on switch on it turns green and a split second later it turns yellow. whats wrong?
This is typical when there is no communication with video card. Test on another PC. Re-seat video card on PC. Use VGA cable instead of HDMI or DVI. Make sure monitor is correct mode. Again VGA, DVI, or HDMI, depending on cable used.
Aug 27, 2012 | Philips Magnavox Computers & Internet
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I replaced the ty-la1000 lamp and now when you turn it on the green light comes on then a yellow one blinks and won't come on what do I do
Which light is blinking yellow/orange and can you count how many blinks in 5 seconds its doing and let me know as thats an error indicator.
Jun 09, 2011 | Panasonic PT-43LC14 43" Rear Projection...
Magnavox 15mf605t/17 15'' LCD HDTV won't turn on
Have similar TV. If it is set to the PC source, it goes into standby when there is no signal, like a regular monitor. Even though the monitor is in standby, you can still press the Source button to change to, say, HD input, and will use the familiar on/off action when pressing Power on the remote.
A little weird, but I've gotten very used to it.
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Tv won't turn on
I did a 2nd replacement with an original Panasonic TY-LA1000 Lamp, now my TV works just llike new.
Dec 17, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Magnavox HDTV model# 15mf605t/17
Just figured this out based on a description of features.
You must power on the TV with the remote control - if you use only the power button on the monitor, it goes straight to stand by mode (the amber light).
Aug 11, 2008 | Televison & Video
AOMNI Corporation Magnavox 15MF605T/17 15 in. LCD TV Logo
78 people viewed this question
Top AOMNI Corporation Televison & Video Experts
cspassik
Level 1 Expert
Are you an AOMNI Corporation Televison and Video Expert? Answer questions, earn points and help others
