Question about 2008-2009 Ford E250 Van Tire Pressure Monitor Sensor Assembly
2009 e250 no low beam - 2008-2009 Ford E250 Van Tire Pressure Monitor Sensor Assembly
  • Vincent Carlone Oct 21, 2013
    head lamps ok fuse ok swapped relays no low beam
    Champion:
  • 473 Answers
Change the switch.
Posted on Oct 21, 2013
My 2009 impala blows low beam right side every couple week
When working is light as bright as the driver side low beam ? Dim ? What's the headlight socket look like ? Burnt ? high resistance ,drawing to much current . Do you know how to do current draw testing ., Voltage drop testing ? Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Feb 21, 2017 | 2009 Chevrolet Impala
2009 malibu headlight
must have a loose connection or broken wire.making intermitten contact. Hope this helps good luck
Mar 31, 2014 | 2009 Chevrolet Malibu
High beams working on aveo but low beams won't come on
You have to replace the headlight bulbs. There are two elements in each bulb one for low beam and both for high beam. The low beam burns out first...
Mar 09, 2014 | 2009 Chevrolet Aveo
My 2009 Honda Pilot headlights low beam will NOT go off
hi..
1.this is because there is some short circuiting occuring in the system.(probably near the switch) this by passes the switch so that the circuit is remain always closed and light is always on. please trace the line of the low beam light before the switch and make proper insulation of wire it wil good.
2.the switch might have damaged. so replace the switch and try.
if my answer were useful please vote for me
Jul 11, 2010 | Honda Pilot Cars & Trucks
I have no low beams on my 2009 Acadia. Fuses are
could be two blown bulbs or the control switch
Apr 17, 2010 | 2007 GMC Acadia SLE
My headlights need adjusting on my 2009 Ford Focus. Then point too low and have no night vision
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Nov 18, 2009 | 2009 Ford Focus
How do i adjust the aim of headlights on 2009 chev equinox
Nov 12, 2009 | 2009 Chevrolet Equinox
My low beam lights sometimes stop working i still have high beam and daylight runing lights after a while they come on.2009 elantra dealer can't find problem.
when the low beams quit try switching from high to low and back and see if low beams stay on, if they do it may be the dimmer switch, if that doesn't change anything suspect the headlight switch.
Sep 02, 2009 | 2009 Hyundai Elantra
CRV headlights
Aug 07, 2009 | 2009 Honda CR-V
2008-2009 Ford E250 Van Tire Pressure Monitor Sensor Assembly Logo
56 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
