Question about Drills
Aeg chuck 18 volt
One of the chuck jaws has come out .how do I get it back in . how do I remove the chuck also from the drill body.
    Master:
  • 483 Answers
Yeah, you'll need to replace the chuck. to remove the chuck generally takes a special tool.that fits between the drive and the chuck, that keeps the drive from spinning when you unscrew the chuck, this tool varies by manufacturer,
Posted on Oct 21, 2013
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
frankzen
  • 19 Answers
SOURCE: Jobmate 18 volt chordless drill charging
About 60 minutes...max 90 minutes. Do NOT leave it on the charger for hours and hours...that just cooks the battery.
And switch regularly between the two batteries...else the one that doesn't get used will die.
Posted on Apr 04, 2009
  • 10865 Answers
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Posted on Apr 30, 2009
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
  • 27 Answers
SOURCE: the chuck is stuck on 18 volt dewalt drill
It is not the chuck that is stuck, it is probably the armature. Probably a problem with the brushes. Since it is so easy I would try first unscrewing the caps and pulling the brushes out to see if things spin then. If the brush will not come out then it is probably jambed and you would have to take the drill apart. If you take the brushes out and still have a problem, at least one reasonable but simply checked problem is eliminated.
Posted on Nov 03, 2009
Chuck jaws on my dw960 arent aligned
It sounds like that the chuck jaws are out of alignment. You will need to get a new chuck.
Nov 09, 2012 | Makita 18 Volt Cordless Hammer Drill Kit ...
Remove drill bit from 18 volt drill
Put the dril in forward, hold the collar, and just bump the switch long enough to get the internal portion to turn. The bit will likely fall out at that point.
Keyless chucks are make in a way that each of the jaws have an exposed heel that can grab onto larger bits that were inserted too far into the chuck.
Feb 14, 2012 | Hitachi Drills
My AEG 630 watt drill SBE630RX. The keyless chuck is seized and will not release drill bit. This is used on a regular basis if this is any help. Many thanks. Trev
The cover on the chuck must be removed by using a punch, tapping around the drill side. this will pop off the cover exposing the jaw's. then use a channel lock and or bench vice on wheel that surround's jaw's. if the chuck is no good it may have a left hand screw in the bore that must be removed to take chuck off.
Apr 20, 2010 | Drills
Chuck jaws on Makita 8444D fell out
There is suppose to be a flat head Left hand thread chuck screw in there. It may have fallen out. You will not be able to put the jaws back into the chuck. You will have to replace the chuck with a new one. If you make sure that the chuck screw is not there you can remove the chuck with a couple of steps. Make sure the drill is in it's lowest gear. Use a strap wrench or some large vise grips on the chuck. If there is still one jaw in the chuck make sure it is all the way open and locking the collar to the chuck. The chuck will come off in the regular lefty loosey configuration. It may be stubborn. If this is the case, You may have to cut the collar off the chuck and use a pipe wrench. Or bring it to a professional to get it changed out.
Sep 23, 2009 | Makita 18 Volt Cordless Hammer Drill Kit ...
Drive bit won't come off drill
You can use a punch and hammer to tap the jaws back in slightly and turn the chuck as you do this to each jaw. This will at least let you get your bit out. You need to hit it hard enough to move it but not too hard as to damage it. Finesse it. After removing the bit try working the chuck jaws in and out all the way. If you feel resistance you may want to get a new chuck.
Sep 12, 2009 | Dewalt 18 Volt Compact Drill Kit
My dc927 chuck is jammed fully open and won't move. How can I lossen it. Regards George
Something I would try:
George, look down the center of the chuck jaws with a bright light. It's going to be difficult to see, but there is an Allen head screw down in there.
Taking the screw out, will afford you the opportunity to remove the chuck from the drill. The drill should have a slightly tapered shaft, and the chuck has a tapered hole to match. It might be stuck on tight. Tap on the back side of the chuck, with a wooden block, and hammer.
(Yes, this may require a helper)
Tap on one side, then the other to try to remove the chuck evenly.
With the chuck off it may release pressure on the jaws. It may not.
In this case the chuck will have to be opened up, (Which will release pressure on the jaws), and the jaws reset.
Aug 22, 2009 | Dewalt 18 Volt Compact Drill Kit
Can't remove bits
I had this problem on my De Walt DW912- I simply couldnt turn the keyless chuck to remove the screwdriver bit and there was no obvious reason why.
I placed the unit on a solid surface so that the chuck/ drill bit was pointing vertical. I then used a mallet and a metal chisel to gently tap each of the 3 chuck jaws back into the chuck body. It worked!
Turned out that there was the absolute tiny amout of corrosion between the jaws, and the chuck and my tapping had just broken the siezure. I now remember that it started to rain slightly last time I used it.
Some spray release agent or perhaps WD40 would probably have done the same job but I wouldnt have believed so little corrosion could have done this so didnt realise this was the problem.
Mar 17, 2009 | Dewalt 18 Volt Compact Drill Kit
Replaceing chuck on a Dewalt Dw511 1/2" hammer drill.
Open the chuck jaws and you will see a screw in the center of chuck, it is left hand thread. remove it and use a large bent handle allen wrench putting the short portion in the jaws and tightening. Shift the drill to the low position and have the clutch in the drill only position. place the handle of the wrench at about a 30 degree angle to strike it counterclockwise. put the chuck on a block of wood or workbench and hit it, this might take a couple times but it will come off. Let me know if you still need help
Mar 09, 2009 | Dewalt 18 Volt Compact Drill Kit
How are the jaws replaced in a keyless chuck?
They are not, you need to buy a new chuck. The tolerance is so close on the collar that you can't repair it. On some of the older keyed chucks you could but the jaws cost about as much as a new one.
Feb 19, 2009 | Dewalt 18 Volt Compact Drill Kit
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
177 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
