Question about JVC SR-V10U S-VHS VCR
Can't insert tape into deck
After removing a tape which wouldn't completely eject (it went only to the point of being flush with the exit hole, with the right side slightly protruding ... I needed to pull a bit to get it out), I can no longer feed new tapes into my S-VHS deck. The tape goes in until it protrudes only about a half inch, but the motor never takes over to pull the cassette in. Everything was working fine tape after tape until I dealt with that faulty tape (I knew it was faulty because it usually refused to load completely, ejecting itself instead; however, it eventually loaded, played OK, but then had the ejection problem mentioned above). I've removed the cover from the deck but don't see anything obviously amiss (no loose or obviously snapped parts). Thanks for any help.
  • 11 more comments
  • GBsLaw Sep 28, 2007
    Hi. I very much appreciate your response. I just finished trying out this suggestion. However, I could not get the carriage to move any further toward the front. The sides of the carriage itself consist of white plastic pieces that have pegs which ride in a metal slot. In the current position, the pegs are all the way to the end of the slot. Perhaps there is another degree of freedom that allows a portion of the carriage to continue to move forward? I couldn't figure out if there is some sort of latch which might permit additional movement. Any other suggestions? I'd be happy to provide specific info on what I see inside the case if it helps with the diagnosis. Thanks very much in advance!
    David
    I will take multiple photographs after work today and send them. I very much appreciate your willingness to take a look.
    David
  • GBsLaw Sep 29, 2007
    Hi Shuttle83,
    I've posted a series of photos here:
    http://www.flickr.com/photos/61375723@N00/sets/72157602205803977/
    If you can view these, I hope they are helpful. Please ask if you want additional close-ups of a particular section. The photos showing a partially-inserted cassette indicate just how far in the cassette will go before meeting strong resistance. I've also taken a couple of shots through the front slot because, to me, the carriage looks slightly tilted. Could just be sloppy manufacture or the way it's designed, but I wanted to at least show this in case it's a clue.
    Thanks very much again for helping me out.
    David
    You may need to cut and paste the link I've posted, as the web site doesn't correctly turn it into a clickable link.
    Thanks,
    David
    By the way, when I first remove the cover, there's a metal bar above the carriage that blocks some of the view and seems to do nothing (supports the front lip of the cover, perhaps)? I've taken one shot of this bar in place but then show the rest of the images with the bar removed.
    David
  • GBsLaw Oct 01, 2007
    "Do you see the gears on the right even attempt to perform the loading function?"
    When I insert the cassette, I don't hear any noise or see any movement other than the slight movement of the carriage as parts flex against the pressure of my pushing (gently). It's as if the VCR weren't even plugged it. When I insert the cassette to the distance shown in the pictures, the resistance to pushing any further is quite strong. I can maybe move it a 2-3 millimeters, basically by causing parts to flex slightly rather than through any designed movement.
    Is there anything about the sensor that would relate to the fact that the problem started after removing that problem tape?
    If photos of the sensor or gears would help, just tell me where to point the camera and I'll take more photos.
    Thanks!
    David
  • GBsLaw Oct 04, 2007
    Hi Shuttle83,
    I appreciate your caring enough about the solution to my problem to discuss it with your colleague and to offer to perform the repair. If the offer still stands, I would gladly pay the shipping to/from your location in order to have the repair done right. While I actually have an electronics background (I do semiconductor device development now, but did board-level design of evaluation boards for DSP chips in a past life), I don't have access to some of the required equipment (schematic, tape tension tool, optical power meter) and, in my present housing situation, have not had the space to unpack the remaining tools and "set up shop." Please let me know how'd you like me to proceed ... I'd like this to be as convenient for your schedule as is possible.
    My sincere thanks,
    David
    Hi Shuttle83,
    Thanks again. I'll get the VCR shipped ASAP. Let me know how you'd like me to cover the return shipping. I could include a check with the VCR, pay you through your business via credit card or transfer money via PayPal.
    David
  • GBsLaw Oct 09, 2007
    Shuttle,
    I've shipped off the VCR to the address that you listed. I want to once again reiterate my appreciation for all your help. I've printed out the above dialog and included it in the box so that you know it's from me. Let me know how it goes once it arrives!
    David
  • GBsLaw Oct 12, 2007
    Shuttle83,
    I'm grateful that you were able to do this, and do so quickly. I look forward to getting it back and will perform the suggested actions (including providing an outstanding rating). Am I correct that the wear issues on the belt and carriage impact only loading and not playback quality? I can live with that and will order a drive belt in the meantime (do you sell them or can you suggest a source?).
    Thanks immensely,
    David
  • GBsLaw Oct 17, 2007
    Hi Shuttle83,
    I'm wondering if you were able to ship out my VCR yet. Nothing's arrived as of today and I don't have a means of tracking it (I included a return label in the box, but I think you may not have noticed it because it doesn't yet show up on my ups.com account as having been used). If you've shipped it already and have a tracking # handy, perhaps you can check it and let me know the status (to avoid having to post the # here). Thanks again for all your help thus far!
    David
  • GBsLaw Oct 20, 2007
    Hi Shuttle83,
    Yes, the VCR just arrived. However, the box split along one edge, potentially exposing the unit to shipping damage, and I want to photograph the box before I open it (since I did insure it and want to make sure I'm covered if UPS caused damage). Once I do this (didn't have time this evening), I'll open the box and hope that the split was immaterial. I do have some lithium grease and will open the case and apply the grease as you suggested. I'll also find your business listing to rate you. Thanks again!
    David
  • GBsLaw Oct 21, 2007
    I'm going to have to set aside time to examine the VCR closely. Upon opening the damaged box, I see that the VCR is also damaged. The back panel is protruding past the metal cover lid along one corner and is cracked, with the metal lid having a crease in one corner. Looks like crush damage. Also, there's a mar on one edge of the front panel like it was hit by an object. I plan to file with UPS for some damage recovery, since the driver noted the damage in his comments section and I photographed the box before opening. If the "guts" of the unit work well, I may still get sufficient use out of it. I'll let you know.
    Genius:
  • 1,139 Answers
Remove the cover again and move the tape carriage all the way towards the front (the carriage is not fully in the locked position). Once that is done you should be able to load a cassette again.
Posted on Sep 27, 2007
  • 8 more comments
  • Henry McKelvey
    Henry McKelvey Sep 28, 2007
    If you can could you supply a picture of the unit (open condition) with close ups of each side what I think might be happening is the carriage is jammed or the drive motor gear might be stuck, in any even send me a photo of the carriage. If this does not work you may have to manually turn the gear to free it. Let me know how things work out.
  • Henry McKelvey
    Henry McKelvey Sep 30, 2007
    Hello GBsLaw,
    I looked at the pictures. And it looks like the load and unload motor is not coming on fast enough, this indicates to me a sensor problem of a gear slippage. Do you see the gears on the right even attempt to perform the loading function?
  • Henry McKelvey
    Henry McKelvey Oct 03, 2007
    I have been talking about your device with an associate of mine and we agreed that one of your sensors might be malfunctioning because it is not sensing the tape in its present location and is not sending the signal to tell the motor to spin. She was telling me that one of the biggest problems she has seen in her shop was that the sensors (either mechanical or optical) get out of alignment. I have seen this in older VCRs with mechanical tape sensors but not with optical sensors. I can tell you they are a pain to work with. What I could do, is because of the work involved, I could forgo my usual service fee and have you ship the unit to me for repair and then I would ship it back to you. Of course, this would mean that you would have to pay for shipping in both directions. This is just a possible option and you are in no way obliged to agree to this suggestion. It is just a suggestion. Why would I do this? (forgo a service fee), because I would rather fix this unit knowing what to do and having the equipment to do it, then to have you try it (hit and miss) and possibly damage the unit. The website of my shop ishttp://www.electron-age-technologies-llc... if you think this option suits your needs you are welcome to send the unit, if not I will try to walk you through the procedure, the equipment you will need is as follows:
    1) Multimeter (to measure the voltage delivered to the load and unload motor and to measure the resistance value of the motor windings)
    2) A schematic to inform of voltage measurements.
    3) Optical power meter (to measure the output of the optical sensor if one is used as opposed to a mechanical switch type sensor)
    4) Anti-static mat and anti-static wrist strap (to prevent Electro-Static Discharge ESD from zapping the microprocessor and other ICs on the circuit board.
    5) Assorted tools screwdrivers, needle nose pliers, tape tension tool and other
    Having said all of this I am still willing to go about this the way that we have been if you really want to do it yourself.
    Thank you,
    Shuttle83
  • Henry McKelvey
    Henry McKelvey Oct 04, 2007
    Hello GBsLaw,
    The offer still stands, here is the shipping information:
    Henry A. McKelvey
    7023 Onyx Court
    Capitol Heights, MD 20743
    Once I get the unit, I'll start on repairs and provide details into what I found the problem to be. Once the unit is fixed (within 3-4 days) I'll send right back with what I found and what I did to fix the problem.
    Thank you,
  • Henry McKelvey
    consider the service as free, just pay for the shipping, the Post Office or Fedex provides RMA mailing stickers for return mailing authorization.
  • Henry McKelvey
    Henry McKelvey Oct 09, 2007
    Hello GBsLaw,
    No problem in fact I'll include a step by step event log of what I do so that you'll have an idea of what happened in the repair of the unit.
    Thank you,
    Shuttle83,
  • Henry McKelvey
    Henry McKelvey Oct 12, 2007
    Hello GBsLaw,
    The unit is working now, I'll be sending it back to you later today. It was just as I thought. Some of the loading mechanisms had become misaligned, so after aligning them and I started to work on the real problems first the loading motor would not function so I found out why the gear the is second from the main gear was stuck after freeing it the motor turned and the carriage functioned as normal. Now because of all the trouble the drive belt is a little streched and because of some of the stress on the carriage it is a little loose, but still within operating parameters.
    When you get the unit back I have two things that I want you to do:
    1) get come lithium grease and put it on the carriage where the white plastic tabs are in the metalic groves. these areas need to have lubrication.
    2) eventually get a new rubber drive belt for the load and unload motor (the old one is a little streched)
    That's all when I send the unit I'll send you the tracking number and estimated time of arrival.
    Also once you get the unit and try it out. go to my business area and rate me there, since I did the work at my shop.
    let me know once you get it.
    Thanks
    Shuttle83.
  • Henry McKelvey
    Henry McKelvey Oct 18, 2007
    Hello GBsLaw,
    I apologize for the delay I just got it out today the tracking number is 1Z500Y739095012419.
     Basically I had to disassemble the carriage and the reassemble it, this after I was finished the first time, I took it apart because I did not like how loose the loading gear arms were, so I just took the whole assembly apart and tightened what I could and now it loads a lot smoother. When you get it make sure it functions to your liking. The plastic parts wear out after a while if you don't grease them now and then. Well let me know how you like it once you get it back. Remember if the carraiage tray drops again, in this or any other VCR, release the drive band and by hand turn the load / unload gear and this will free the tape. Turn a few more times and it will put the carriage back into the proper position.
    I hope this helps,
    Thank You,
    Shuttle83
  • Henry McKelvey
    Henry McKelvey Oct 20, 2007
    Hey GBsLaw,
    Did you get the VCR yet? If you open it up you'll see that all of the load and unload components are back in thier proper tracks, and that I did do some minor work in lubricating the track, but you'll have to get some lithium grease and just apply a little to the track mechanism.
    I hope that it meets with your approval,
    Thank you,
    Shuttle83
  • Henry McKelvey
    Henry McKelvey Oct 21, 2007
    Hello GBsLaw,
    I am so sorry, I apologize if anything I done lead to this. Let me know if I can be of assistance in the filing of a complaint against UPS. Also let me know if you need any explanation of how the unit was shipped. Again I hope that I can still be of assistance on resolving this issue.
    Thank you,
    Shuttle83
How to eject an HDCAM tape stuck in as BVW75 Beta deck.
I don't know what this error code means but I have managed to remove tapes which stuck in a VCR and cannot be ejected. Whether you do this is purely up to you, but it's usually possible to remove the casing (carefully!) so that you can get to the tape-handling section. Then it's a matter of gentle probing & trial and error to get the machine to release its hold on the tape. Look for a series of mechanically linked parts which are driven by motor but activated by a microswitch tripped by action of inserting the tape. Just don't strain the linkages and if you remove anything make a note of where it came from.
Apr 28, 2015 | Televison & Video
Flashing code C:32:11
Remove the battery. Re-attach the battery, and power up the camera. Should retutrn to normal.
Jun 03, 2008 | Sony Handycam DCR-TRV140E Digital...
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
Cassette stuck in the dash. eject button will not eject the cassette
You should take the tape deck out of the dash. Most aftermarket ones have two pairs of holes that you can insert long nails into to disconnect it from the dash. Unplug all the wires and open it up. It has probably eaten the tape and you will have to cut it and pull the strands off the capstan to get the cassette housing out. A pair of forceps, tweezers, and wooden handled cotton swaps and rubbing alcohol are helpful for cleaning and removing the strands of broken 3 7/8 ips tape.
Mar 04, 2015 | Chrysler 2002 Concorde LXi
Tape isn't retracted into cassette upon eject on Sony EV-C100
l would sacrifice a old or bad tape here, remove all the tape inside a cassette and tape off the small sensor holes on each side.
That way no tape to damage and you can insert it to see what is happening.
What likely is the issue is when stop it, it or if the tape does not fully load against the drum with heads, when the arms retract that pull the tape out of the cassette the mechanism is not switching to rewind it back into the cassette.
Usually this means a belt is slipping or the idler unit is not working---belts can break or stretch or even come off---belts will get slopply or bad from NO use and it is common.
Dec 09, 2012 | Sony Video Hi8 Ev-c100 Ntsc Video Cassette...
Where can I buy Pioneer CT-W701R Stereo Double Cassette Tape Deck Riemen Belt
If the methods listed in the manual won't open the door, then the tape is not inserted properly. Insert a golf tee in one of the two small holes below the tape door and slightly adjust the position of the tape up, down, or sideways. Then press the eject button and it should open. This will only work if the belt is OK.
Apr 26, 2012 | Pioneer Audio Players & Recorders
Tape deck is stuck
push the eject button at the same time get a nail file and insert it in the tape slot
on the right hand side of the deck
it may take three hands one to push eject one to push the eject mechanism inside the radio behind the tape
and one to help remove the tape
if that doesnt work....dont try forcing anything as the stereo WILL break..... take the stereo out of the car, so it is not connected to the electrics, then either, gently take it apart with a screwdriver
I would suspect the belts, look for any small motors and missing belts. You may be able to manualy turn a wheel or gear till it ejects.
if your not comfortable doing this urself with the above said porcedures... its better to take it to the dealer...
regards iversh
A very helpful rating is appreciated for answering Your Query
Aug 30, 2009 | Panasonic RX-ED707 Boombox
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Inserted tape into the cassette and the door will not open so I can remove it and it will not play as inserted.
use a paper clip to release it. there is a tiny hole located close to the deck, insert the pin and it shuold open. the tape might be tangled...
Jul 02, 2009 | Audio Players & Recorders
JVC SR-V10U S-VHS VCR Logo
302 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
